Installing Type_r tb's cable in hybrid gsr-97 tomorrow, need some quick tips
Old Nov 14, 2004 | 11:18 PM
yeegsr's Avatar
Default Installing Type_r tb's cable in hybrid gsr-97 tomorrow, need some quick tips
ok...my hybrid is gsr97 in C-95 coupe, tomorrow ill will install the cable and run it across my BLOX IM, need some advices
i read the helms manual about installation
they say, make sure throttle blade is fully open then install cable's housing into the bracket
is this step go after i installe the other of the cable to the gas pedal or what....what are the sequences of installing a type r cable...(i have everything ready, pulley, bracket..etc)
will someone please nice enought to write up some step please...for guys
Old Nov 15, 2004 | 01:53 AM
yeegsr's Avatar
Default Re: Installing Type_r tb's cable in hybrid gsr-97 tomorrow, need some quick tips (yeegsr)
ttt
Old Nov 15, 2004 | 04:01 AM
IN VTEC's Avatar
Install the pedal-side first b/c you'll have greater space limitations working on that end. You don't need the tension giving you a hard time on top of it.
Crank the throttle pulley wide open with you hand to install the cable.
Lastly, pull the cable as needed to get the neck through the bracket hole and then adjust the tension as needed.
yeegsr
Nov 15, 2004 07:38 AM
DeKaP
Aug 31, 2004 06:23 PM
rockwilda
Aug 27, 2002 12:40 AM
rockwilda
Aug 25, 2002 08:32 PM
ic108
Dec 5, 2001 11:10 PM
