take a guess to fix my car (91 teg)
i guess i could start with what i did and have to go back over...
i checked for spark, i had a very weak sparka yellow not blue like a good spark is... but after doing that i thought the coil was bad, weak spark made sense cause ignitors are work or nor work, not giving weak spark i was told.
so i had it apart and i looks and found my dist. rotor was melted on the dist., WTF?! and it was firing off timing by 3 cylinders... so i got a new one on, and the cap was replaced i can obviously tell but i have an MSD cap and Accel coil to go external if i need to...
basically it seemed closer to starting with the bad rotor in it, why?
so i am about to go bac and check spark again, if still weak i an going to convert to external coil...
oh i am getting fuel cause the plugs getting getting fouled... and the timing belt is still intact...
what else could this be?
thanks
Modified by JustinG60 at 7:08 PM 11/14/2004
thanks
spoonhbk11
11
Jun 9, 2019 07:03 PM
