will an 99-00 SI header fit on a 98-99 LS perfectly?
Old Nov 14, 2004 | 03:56 PM
TrueUntilDeath.com's Avatar
Default will an 99-00 SI header fit on a 98-99 LS perfectly?
dont ask why, just a simple yes or no would be great.
Old Nov 14, 2004 | 04:26 PM
hondaeg8's Avatar
Default Re: will an 99-00 SI header fit on a 98-99 LS perfectly? (FrostWhiteDC4)
no...the si header is shorter. it will bolt up to the head fine, but it won't reach all the way back to the cat. you will need to add some extra piping for it to work perfectly.
Old Nov 14, 2004 | 05:34 PM
shorto85's Avatar
The flange for the header and the cat wont line up correctly
Old Nov 14, 2004 | 05:41 PM
dFreezy's Avatar
Default Re: (shorto85)
the main reason it won't work is because it won't clear the oil pan.
Old Nov 14, 2004 | 06:23 PM
Padawan's Avatar
Darth ModerVader
Default Re: will an 99-00 SI header fit on a 98-99 LS perfectly? (hondaeg8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaeg8 &raquo;</TD></TR><TR><TD CLASS="quote">no...the si header is shorter. it will bolt up to the head fine, but it won't reach all the way back to the cat. you will need to add some extra piping for it to work perfectly. </TD></TR></TABLE>
This is incorrect. The Si and LS manifolds are exactly the same length.
Old Nov 14, 2004 | 06:34 PM
black_cap's Avatar
Default Re: (dFreezy)
it wont clear a b18c from what I researched
Old Nov 14, 2004 | 06:42 PM
Default Re: (black_cap)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black_cap &raquo;</TD></TR><TR><TD CLASS="quote">it wont clear a b18c from what I researched</TD></TR></TABLE>
im talking about a b18b though
Redemption
Jul 14, 2007 03:43 PM
AZNBIGPIMPN505
Dec 14, 2004 03:02 PM
JDubya
Oct 18, 2003 11:05 PM
jonas
Oct 5, 2003 04:38 PM
b18bfreak
Jun 30, 2003 07:45 PM
