broken thermostat needle ?
Old Dec 26, 2001 | 03:38 PM
M0NEYnH0s's Avatar
Default broken thermostat needle ?
I have a broken thermostat needle, not totally broken but when the car just sits there idling then the needle will work. but after i drive around for a while it will just rest back on the cold side. Anyone know whats wrong with it? Not to mention my heat freakin sucks bad. could the broken needle have anything to do with that?
thanks
Old Dec 26, 2001 | 03:42 PM
lsvtec's Avatar
New User
Default Re: broken thermostat needle ? (m0neynh0s)
This is kind of a wild guess, but have your replaced your thermostat? It could be stuck on full open. Does you heater work when you start driving then go cool when the car sits?
Old Dec 26, 2001 | 08:30 PM
M0NEYnH0s's Avatar
Default Re: broken thermostat needle ? (lsvtec)
i dont think the thermostat has ever been replaced, ive only had the car since about oct. but after the car gets warmed up then the heater stays warm. it jus takes, in my opinion, a long *** time to warm up. what do you mean by stuck on full open?
its like on a cold morning when i start my car, i let it sit for about 3-5 minutes atleast before i drive it. its still cold even after that. I drive it for a while and then the heat will start to kick in, but on the needle it still points to cold. say i hit a train and end up sitting there for a while, the needle will slowly creep up to about half way but after i start moving again itll fall back down.
Old Dec 26, 2001 | 08:57 PM
Mista Bone's Avatar
D Tranny Guru
thermostat suck open. Once you start moving again, airflow through the radiator is cooling car back down.
Old Dec 27, 2001 | 07:40 AM
M0NEYnH0s's Avatar
Default Re: broken thermostat needle ? (Mista Bone)
is there any way to fixit or do i jus have to replace it?
thanks
Old Dec 27, 2001 | 08:18 AM
Mista Bone's Avatar
D Tranny Guru
fix = replacing. Only $5-8 for the thermostat.
Old Dec 27, 2001 | 09:41 AM
HiRevn's Avatar
My car did the same thing. I replaced the thermostat and it works fine now.
90_civic_Si
Dec 12, 2009 09:37 PM
ivan93egreppin210
Feb 3, 2009 04:29 PM
jmkc
Nov 5, 2005 09:24 AM
kevin85193
Dec 4, 2004 06:24 PM
PM-Performance
Feb 1, 2004 07:09 AM
