FS 95 civic with gsr swap and lots of goodies
Old Nov 14, 2004 | 02:52 PM
fufu's Avatar
Default FS 95 civic with gsr swap and lots of goodies
pictures are post on http://www.imagestation.com/mypictures/inbox/
user
password: 1234
here is complete list of mod
95 civic hatch back with jdm gsr engine, type r transmission (lsd and 4.75 final drive)
no power steering, no ac (reduce engine load and its race car set up) brand new paint in july,
engine: obd1 95 jdm gsr engine, spoon flywheel, type r cams, mugen valve springs, portflow titainium retainers, new oem timing belt, ngk iridium spark plugs, msd spark plug wires, stage 3 port and polish head, mugen thin head gasket (10.9 compression ratio), mugen header (has jasma and mugen stamps), high flow catalytic converter, k&n intake, jdm kakimoto full exhaust system, aem lightweight alternator pulley, jdm honda n-1 lightweight crank pulley, energy suspension motor mount insert, obd1 p72 ecu with mugen chip
spoon magnetic drain plugs for engine and tranny, spoon thermostat, spoon radiator cap, spoon iridium racing plugs, spoon throttle body
transmission: jdm type r transmssion with stock lsd, 4.785 final drive, spoon clutch, new release and pilot bearing, new crank seal (no need to worry about remove tranny to replacing bearings, clutch or seals)
brakes: jdm gsr front and rear brake spindles and trailing arms, front brembo slot rotors,rear blank brembo rotors, hawk hps pads, type r brake booster with master cylinder
suspension: 4 wheel disc, tanabe sustec coilovers, type r front and rear sway bar, spoon trunk tower bar, 15" spoon sw388 wheels (8.5lb each)(please check spoon wheel price at http://www.inlinefour.com), spoon lug nuts, michlin vr4 tires
interior: jdm sir guage cluster, 1 piece carbon fiber panel, razo pedals, honda oem floor mats
exterior: brand new stock red paint painted at a&b auto, stock foglights, white signal housing with super white bulb
stereo: alpine 4 channel 20watt amp, sony md deck, alpine front 6.5" mid and tweeter components speakers, rear 6x9 planet 2 way speakers
the car well maintain use synthetic engine oil, synthetic tranny fluid and synthetic brake fluid and change engine oil every 3500km
thats all i can think of for now, there should be more mod but i can't remember now
ps: it has new distribtor, new o2 sensor, new water pump, new oil pump, new axles, remote start, remote lock and alarm system
let me know if you are interest of my car i am asking 13500$CDN
may consider trades
my email alex_f15@hotmail.com
TcUiRvBiOc
May 29, 2008 02:08 PM
tracetec2000
Northeast (Sales)
18
Oct 22, 2006 03:20 PM
badkarma
Jul 15, 2004 12:07 AM
steve9927
Mar 6, 2004 07:23 PM
SpeedFiend
Jul 14, 2003 08:43 AM
