Checking Ecu Codes.
Old Nov 14, 2004 | 01:29 PM
HamiltonRex's Avatar
Default Checking Ecu Codes.
Alright.
I have a obd1 converosin using blown90hatches harness.
When i ground the wire to check for codes, my check engine light comes on and stays on if there are no codes, if there are codes it will flash the code.
It should come on and stay on when i ground the wire if there are no codes right?
Or does that mean bad ecu or something?
Old Nov 14, 2004 | 01:34 PM
CRX_Control's Avatar
Default Re: Checking Ecu Codes. (HamiltonRex)
yeah your right
Old Nov 14, 2004 | 03:38 PM
Mr_CRX's Avatar
Yeah, if you have no codes, and ground that wire, it will be a solid CEL.
Old Nov 14, 2004 | 03:41 PM
CrazyKoreanCrx's Avatar
Default Re: Checking Ecu Codes. (Mr_CRX)
You have a toggle switch on it right?
Old Nov 14, 2004 | 03:45 PM
Default Re: Checking Ecu Codes. (CrazyKoreanCrx)
sure do
Old Nov 14, 2004 | 03:46 PM
ok, then your kool.
hatchinprogress
Nov 19, 2009 08:18 PM
Tw1n Turb0 Z
Feb 11, 2007 11:08 PM
Tw1n Turb0 Z
Oct 9, 2006 06:18 PM
gocivicgo
Aug 11, 2003 03:43 PM
