Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Rear Brake Problem
Old Nov 14, 2004 | 11:15 AM
danmoore80's Avatar
Default Rear Brake Problem
I pulled off the rear wheels, removed the calipers, took old pads off, put new ones into place, and WTF now it doesen't go on the rotor. I then walked into the garage, grabed a "C" clamp in order to compress the "you know," only it would not compress. I removed the reservoir cap, and loosened the nipple behind the caliper(I slipped a hose with brake fluid over the nipple prior to loosening to prevent air from getting into the line)but it still will not compress. What am I doing wrong? Any help is much appriciated. Thanx
Old Nov 14, 2004 | 11:24 AM
jsi's Avatar
jsi
Default Re: Rear Brake Problem (danmoore80)
Sounds like you have a seized caliper. Get a new one or a rebuilt one.
Old Nov 14, 2004 | 11:49 AM
FlyZlow's Avatar
Default Re: Rear Brake Problem (jsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jsi &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like you have a seized caliper. Get a new one or a rebuilt one.</TD></TR></TABLE>
very likely ... if it is just hard to depress the piston because the C clamp won't fit on it right, try picking up a disc brake spreader from autozone or checker
were you having some kind of problem that made you want to change the pads in the first place?
Old Nov 14, 2004 | 12:24 PM
danmoore80's Avatar
Default Re: Rear Brake Problem (FlyZlow)
no, I just bought the car, and wanted to change the brake pads. The rear passenger side brake however would squeel really bad for about the first 5 min of driving and then it would go away.....kinda weird. I will go pick up a spreader and see if that does the trick....thanx for all the help
Old Nov 14, 2004 | 12:53 PM
Chris Sawatsky's Avatar
New User
don't rear brake calipers require that you turn the piston to compress it, rather than force it with a clamp?
Old Nov 14, 2004 | 01:18 PM
Mattamotor's Avatar
Default Re: (Chris Sawatsky)
yes rear brakes twist in ,they do not push in.
Old Nov 14, 2004 | 02:14 PM
.RJ's Avatar
.RJ
Default Re: (Mattamotor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mattamotor &raquo;</TD></TR><TR><TD CLASS="quote">yes rear brakes twist in ,they do not push in.</TD></TR></TABLE>
Thank you.
Christ... why are people posting that you clamp them in. Wrong forum anyways, try tech.
EDWINV00SI
13
Mar 28, 2011 12:40 PM
red91efhatch
Feb 26, 2009 10:06 PM
chevellion
Nov 21, 2007 07:25 AM
pmachan
Jun 7, 2004 05:39 AM
wizzards581
Sep 6, 2003 12:15 PM
