Is this normal on a 90 crx?
Old Nov 14, 2004 | 10:42 AM
DaMmniTz's Avatar
Default Is this normal on a 90 crx?
When i start my ignition my RPM is always above 2k-3k range and my temperture is at basically ZERO. After i let the car warm up for a little ( 15 mins ) the RPM drops below 1k . . approximately 880 rpm. but my temperture is always at ZERO. After driving for about 20-30 mins then it goes up to 20-30% . . . Is it suppose to take that long for RPM to go down to under 1k RPM? and the temperture to rise to 20-30% after 30 mins? I just got a new radiator. . still doing the same thing.
Is there something that i must change? or do?
Any answers or comments will help. Thank you
Old Nov 14, 2004 | 10:48 AM
b17hybrid's Avatar
Default Re: Is this normal on a 90 crx? (DaMmniTz)
Check or replace your thermostat. Only costst about 5-10 bucks and 15-20 minutes of your time. Thermostat might be stuck open.
Old Nov 14, 2004 | 10:52 AM
DaMmniTz's Avatar
Default Re: Is this normal on a 90 crx? (b17hybrid)
okay good idea . .
Old Nov 14, 2004 | 01:09 PM
P h i l's Avatar
i have had 3 crx's and they all did the same thing i wouldnt worry bout it
Old Nov 14, 2004 | 01:15 PM
Zaakro's Avatar
Default Re: Is this normal on a 90 crx? (crxhf89)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxhf89 &raquo;</TD></TR><TR><TD CLASS="quote">i have had 3 crx's and they all did the same thing i wouldnt worry bout it</TD></TR></TABLE>
my hatch did that and i found out that when the temp did go up a little it was over heating
Old Nov 14, 2004 | 04:12 PM
my_little_beast's Avatar
Default Re: Is this normal on a 90 crx? (Zaakro)
it could be your vaccum lines make sure all of them are connected to your manifold.thats happened to me before
xTimmyx
Dec 8, 2009 06:52 PM
jeezyskillz
Nov 21, 2006 11:41 PM
Rex89
16
Oct 8, 2006 08:53 PM
ITR#465
Mar 13, 2006 08:55 PM
90jdmcrxdude
15
Jan 22, 2006 08:55 PM
