help tuning b16a!
Old Nov 14, 2004 | 10:19 AM
BACKintheDA's Avatar
Default help tuning b16a!
I am running CTR cams/ITR valvetrain in my second gen B16a, and at the stock 5200rpm VTEC x-over, i don't get full power out of them.
Since the motor is run obd0, what are my options? I'd basically like to raise the crossover point to 5700rpm, and raise the redline to about 8700. How can I get the most out of my cams with this setup, without having to converty to obd1?
Thanks-
Old Nov 14, 2004 | 12:22 PM
Default Re: help tuning b16a! (BACKintheDA)
anyone?
Old Nov 14, 2004 | 12:44 PM
civicgsr19's Avatar
Cam gears, vafc to switch the x-over to around 5700-5800 and play with afr and a dyno session.
Old Nov 14, 2004 | 12:59 PM
IcEef8's Avatar
Default Re: help tuning b16a! (civicgsr19)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicgsr19 &raquo;</TD></TR><TR><TD CLASS="quote">Cam gears, vafc to switch the x-over to around 5700-5800 and play with afr and a dyno session.</TD></TR></TABLE>
Old Nov 14, 2004 | 03:54 PM
Default Re: help tuning b16a! (IcEef8)
I have skunk2 cam gears, and I guess with a VAFC the x-over can be changed, but that still leaves the stock redline. is there a way to get rid of it?
Old Nov 14, 2004 | 05:00 PM
Old Nov 14, 2004 | 05:27 PM
HONDABROMANDUDE's Avatar
Different program for the ecu is how you get rid of the rev-limiter or move it higher.
Old Nov 14, 2004 | 05:42 PM
Default Re: help tuning b16a! (HONDABROMANDUDE)
so you think a chipped ECU along with a VAFC would do the trick?
Old Nov 14, 2004 | 07:04 PM
civicgsr19's Avatar
Oh yea
Look for ih8ricerz on here, he does a kick *** job chipping ecu's!
tomlinson619
37
Oct 9, 2006 01:41 PM
omg_an_ef8
Jul 6, 2006 06:40 PM
slowacura
Dec 18, 2003 09:13 PM
Red98GSR
Feb 19, 2002 01:57 PM
Mike95lude
Sep 10, 2001 07:16 PM
