What spark plugs to run???
Well I have my motor finally built and got the tranny in a few weeks back, and now I am trying to get the little parts for the motor, check the sig for specs
. My question today is which spark plug to run??
Now before anyone says please SEARCH, just want to let everyone know that I did. People list the NGK BKR7E-11 and the Autolite plugs, because of the higher compression. Also, read a post back about Rocket's Plugs that made a little bit more power. This car will be driven daily about 4 times a week, so with some good tuning and cold plugs, hopefully dont have to worry about detonation.
I really want to know what other people are running with there high compression motors.. Pls respond with recommendations and comments, no flaming though.
. My question today is which spark plug to run??Now before anyone says please SEARCH, just want to let everyone know that I did. People list the NGK BKR7E-11 and the Autolite plugs, because of the higher compression. Also, read a post back about Rocket's Plugs that made a little bit more power. This car will be driven daily about 4 times a week, so with some good tuning and cold plugs, hopefully dont have to worry about detonation.
People have vouched for the NGK R5671A and the come in heat ranges 7-9, I have tried all 3 on mine, it really depends on your set up, injector size and fuel pressure and compression and timing, I personally use the #8s, the 9s were too rich and the 7s were OK but the 8s have worked out the best so far, I have s2s3 with 13:1 cr, hope this helps.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PreStaged12s »</TD></TR><TR><TD CLASS="quote">People have vouched for the NGK R5671A and the come in heat ranges 7-9, I have tried all 3 on mine, it really depends on your set up, injector size and fuel pressure and compression and timing, I personally use the #8s, the 9s were too rich and the 7s were OK but the 8s have worked out the best so far, I have s2s3 with 13:1 cr, hope this helps.</TD></TR></TABLE>
Since when are spark plugs too rich ?
lol
Just run BKR7E-N-11 & call it a day on all motor applications.
lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber »</TD></TR><TR><TD CLASS="quote">
lol
Just run BKR7E-N-11 & call it a day on all motor applications.</TD></TR></TABLE>
By running rich I meant the plugs were to cold which resulted in the fuel not being burned efficiently, when I tried the 7s they plugs ended up being a little bit on the white side and the 9s were too black so the 8s for me have been working out the best.
lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber »</TD></TR><TR><TD CLASS="quote">NGK BKR7E-N-11
Pregapped & all :-)</TD></TR></TABLE>
ordered these about 3 weeks ago.
i have the ngk spark plugs inlinefour.com sells for high compression/turbo motors. they are ngk4554's i believe. il4 sells them for $20 but you can goto napa and get them for $8 or less.
sneakychaos
Nov 8, 2008 04:47 PM
