Help meeeeeee plzzz...... Major engine problems...
Old Nov 14, 2004 | 02:09 AM
AzN_Flava's Avatar
Default Help meeeeeee plzzz...... Major engine problems...
Current motor set up...
2.0 ls/vtec
9.7:1 compression
gsr cams
stock itr header/cat
450 dsm injectors
Okay, today I got the car tuned. They said they tuned the car to 13:1 a/f. I had about 80% engine oil. When I got the car back, the car felt really boggy and bad, and I later found out my cylinder 4 spark plug had fouled up. I go change my spark plug, drive under 50KM and i get home, cylinder 4 spark plug is fouled again.
NO ENGINE OIL or atleast bone dry, had to put in 2.25-2.5 bottles of non detergent oil.
Driving impressions:
1)Car revs extremely slowly.
2)Smoke keeps coming out like crazy like a chimney from my exhaust even when it is warmed up (never did this before)
3)When I gas or shift gears, it sounds like a hissing noise like something is leaking. Sounds likea hose is watering the ground.
4)I hear popping noises occasionally
5)Car idles at 800 (which im happy with)
I have now driven 1 to maybe 2 tanks of gas, and i guess my rings still have not seated. What is going on, and what do i need to do? I guess the tune ain't as accurate? but still, what the heck...
They did full throttle and idle tunning, but yet to really work on partial. But still, this aint normal at all.
did compression test
1-210
2-210
3-220
4-210
Modified by AzN_Flava at 3:19 AM 11/14/2004
Modified by AzN_Flava at 12:27 AM 11/15/2004
Modified by AzN_Flava at 1:03 PM 11/18/2004
Old Nov 14, 2004 | 07:57 AM
mmuller's Avatar
Mad Scientist
Default Re: Help meeeeeee plzzz...... Major engine problems... (AzN_Flava)
so what color is the smoke?
your getting oil in that cyl?
Old Nov 14, 2004 | 08:07 AM
tech1145's Avatar
Does your coolant level go down as well?
Old Nov 14, 2004 | 02:19 PM
AzN_Flava's Avatar
Default Re: Help meeeeeee plzzz...... Major engine problems... (tech1145)
before the tune the smoke was blue, now im not too sure
no the coolant level doesn't really seem to change, teh reservoir is always full
Old Nov 14, 2004 | 04:02 PM
asubennett's Avatar
What process did you use to break in the motor?
Old Nov 14, 2004 | 11:27 PM
AzN_Flava's Avatar
Default Re: Help meeeeeee plzzz...... Major engine problems... (asubennett)
broke it in hard, and I have confirmed it is blue smoke...
blown headgasket?
Modified by AzN_Flava at 8:16 AM 11/15/2004
Old Nov 18, 2004 | 12:03 PM
AzN_Flava's Avatar
hrmmm
did compressiontest
1-210
2-210
3-220
4-210
9.7:1 2.0 ls vtec
1CaMw0nDeR
Jul 1, 2008 07:31 PM
danmanh22
Mar 28, 2004 08:27 PM
senbei
Jul 1, 2003 03:19 PM
93SSPHatch
May 30, 2002 04:27 PM
sa21199
Jan 5, 2002 08:07 PM
