Can I run High Impedance injectors in my CRX
Old Nov 13, 2004 | 11:15 PM
BoostBoi's Avatar
Default Can I run High Impedance injectors in my CRX
Do I have to bypass the resitor box or what
Also how do I do that, I put in 32lb injectors from a Mustang they fit like a glove and the clips work perfectly.
Doing this tomorrow, so please help.
Thanks, Bryan
Old Nov 13, 2004 | 11:49 PM
TrueNorthStar's Avatar
Default Re: Can I run High Impedance injectors in my CRX (BoostBoi)
Yes you can. There are 5 wires running to the resistor box if memory serves me.
What I did was cut all of the wires where they go into the resistor box and connect them together. This way if you ever want to go back to low impedance injectors later you can buy another resistor box ($15) and just plug one back in.
Old Nov 13, 2004 | 11:50 PM
eastbay92cx's Avatar
Yes, remove the injector box. Unplug it, and whatever wires are going through it, you might have to splice them together. I am unfamiliar with 4th gens / resistor boxes, but just make sure the power wire for each injector isn't going through the resistor box and still has continuity.
btw I hope you plan on managing different injectors somehow (ie chipping the ecu / tuning it)
Good luck.
Oh, he got to it first ^------ =]
two81's
Dec 24, 2013 04:36 AM
cehcivic15
Engine Management and Tuning
Oct 21, 2009 08:14 PM
ironcheftony
Apr 14, 2005 02:39 PM
CM-R
Jul 12, 2002 08:20 PM
dustin
Jun 17, 2002 02:09 PM
