lowering with stock springs
Old Nov 13, 2004 | 11:06 PM
ham's Avatar
ham
Default lowering with stock springs
im not sure about this but i heard you get older accord front shocks and civic wagon shocks for the rear and its good for about a 2" drop on crx/EF
true? or correct me if im wrong.
i found stuff about the accord shocks in the front but not too many people know about the rear. the whole point is to drop it a little while still having the stock springs.
Old Nov 13, 2004 | 11:08 PM
EL Vap133's Avatar
Default Re: lowering with stock springs (ham)
I don't think it's a good idea.
Old Nov 13, 2004 | 11:10 PM
MR5sARECOOL's Avatar
By changing the springs most people are looking for a stiffer spring rate as well as lowering. A stiffer rate is something you wont get with factory springs(not enough anyways).
Imagine being lowered and having a stock spring rate going over some long rolling bumps, or cornering. You'd be bouncing like crazy, instead of hugging the road.
Old Nov 13, 2004 | 11:14 PM
ham's Avatar
ham
Default Re: lowering with stock springs (MR5sARECOOL)
i live near detroit and i cant stand having coilovers. i had to take sidestreets to work and i memorized which streets i could drive on. i whether want a nice set of springs and the accord/wagon shocks or just have it a little lower with the stock springs. do you think it would be bad to have stock springs with the accord/wagon setup? its not gonna be a race car, i just dont want to be monster truckin.
Old Nov 14, 2004 | 07:53 AM
Louie B.'s Avatar
Get some Koni Yellow shocks, they have the adjustible pearch height that allows for slight lowering. then get some Ground Control upper mounts that extend the shock travel so the shocks don't bottom out.
lngel
Suspension & Brakes
Aug 6, 2015 07:36 PM
CRX-1991
Jan 26, 2008 08:20 PM
EvenStar
Mar 9, 2007 06:18 AM
vermilion
Suspension & Brakes
Aug 1, 2006 01:14 AM
saver
Suspension & Brakes
15
Jan 27, 2006 02:58 PM
