will a jdm throttle body fit on a sohc zc?
Old Nov 13, 2004 | 10:48 PM
CivicRaping's Avatar
Default will a jdm throttle body fit on a sohc zc?
hey i was wondering if anyone knows if there is a difference between jdm b16 throtle bodies and teh usdm version? Also i was wondering if anyone knows will teh jdm throttle body fit in a zc sohc. some people says it does and some says it will
Old Nov 13, 2004 | 10:55 PM
dr_latino999's Avatar
Default Re: will a jdm throttle body fit on a sohc zc? (CivicRaping)
If you mean the B16A throttle body it will not fit on the SOHC ZC intake manifold which from this point on we will call the D16A6. To attach a B-Series throttle body you need to change your intake manifold to one newer, either from the D15B7, D16Z6, or the D16Y8.
Old Nov 13, 2004 | 11:07 PM
Default Re: will a jdm throttle body fit on a sohc zc? (dr_latino999)
teh d16y8 is the manifold form the 96 to 00 civics right? if so will it fit into teh zc motor
Old Nov 14, 2004 | 05:29 AM
Yes the Y8 manifold is from the 1996-2000 Civic EX, and yes it will bolt onto the A6. The reason I say we shall refer to this ZC as the D16A6 is due to the fact as they are identical in all aspects mechanically, and to not cause confusion with the tons of other ZCs available.
prelude182
Jan 7, 2010 12:34 PM
Jonny Rocket
43
Aug 28, 2007 03:48 PM
909ej195
Jan 19, 2007 06:29 AM
