Brake Light/Rear Wiper Problem
Old Nov 13, 2004 | 09:53 PM
pumonchu2005's Avatar
Default Brake Light/Rear Wiper Problem
I guess I should've posted in this forum instead of the other... but anyway.
I'm new here, and this is my first post. (I have searched on these topics, BTW)
ok, well first off, my high mount (third brake) light on my 89 hatch does not work. Fuses are fine, bulb works, I've cleaned the contacts and multimetered the socket and I'm not getting any voltage. I have also examined the wiring as far I can get to and it looks fine. Are there any other switches or connections up front that I can check?
Also, my rear wiper is buggy. Sometimes it works, sometimes it doesn't. When it does work, it only works when I'm pressing the brake pedal. So perhaps the brake light is shorted with the wiper circuit? I'm thinking that I don't even need it and I'm just going to spray RainX on the window and shave the wiper off. What does anyone suggest?
A little more about these two things:
All the fuses are fine. I've looked at the diagrams in both the engine bay and under the steering column and all the fuses are in place and non-blown (for lack of a better word). The only one I'm wondering about is one up front labelled "Lampe/Light" which the diagram shows as a 50A fuse and there is a 40A in it. The fuse has not blown yet, so it shouldn't be a problem, but then again, it may be restricting current...?
So if anyone has any suggestions, I'd greatly appreciate it.
Thanks!
Old Nov 15, 2004 | 01:53 PM
Default Re: Brake Light/Rear Wiper Problem (pumonchu2005)
Anyone... anyone...?
Old Nov 15, 2004 | 02:59 PM
drdisco69's Avatar
The smaller fuse doesn't affect the voltage. Check the grounds back there. I'm not sure how you tested the socket, but check that it's got continuity to ground, and that there's 12v to a good chassis ground.
Old Nov 25, 2004 | 01:12 AM
Default Re: Brake Light/Rear Wiper Problem (drdisco69)
i figured it out. the wires were kinked some how and broke in the hatch. so i wirenutted them and it works mighty fine now.
studlete
Sep 4, 2009 07:39 PM
91accordwagon
Aug 27, 2006 12:37 PM
dc24me
Apr 10, 2002 08:46 PM
D-Day
May 23, 2001 06:31 PM
