header difference???
Old Nov 13, 2004 | 09:21 PM
SHystrdyGSRtdy's Avatar
Default header difference???
since i know this is the welding section... you guys would pay particular attention to header details...
(if this i am wrong... please move this to the appropriate place.. TIA)
anyways... what is the difference between the jdm header and the US DC header (both being 4-1), anr's header, smsp's header etc.... BESIDES the collector size... specifically... are the US DC headers primaries not as long as the better headers (ie, smsp's, anr's, etc)
again.. TIA
Old Nov 14, 2004 | 08:49 PM
RMF
Guest
Posts: n/a
Default Y
That quote ^ up there is some funny as ****
I having problem...........
Old Nov 14, 2004 | 09:02 PM
Ekasey's Avatar
Default Re: Y (RMF)
Long primaries are not necessarilly better
Old Nov 14, 2004 | 09:27 PM
Default Re: Y (eLusive ek4)
so what makes them expensive headers top notch? besides the quality aspect.. i'm speaking of a design stand point (for an n/a setup)
Old Nov 14, 2004 | 11:12 PM
Ekasey's Avatar
Default Re: Y (SHystrdyGSRtdy)
There are many things to be considered in designing a header for specic application
such as
Primary sizing
primary length
4:1 vrs tri Y
Collector sizing and angle
Tail pipe sizing
on and on etc a header designed to a partciular application is going to compliment that partciluar engine better then another header will
Example i designed a header for a top notch race team SCCA
They chnaged cams hafts built the header the gains showed 38+ hP from 2000-4000 and from 4000-8000 3-4 hp
I redesigned the header i redesigned the header with the new camshaft 2000-4000 gain was 3-4 4000-8000 = 15 + HP
shows how muhc a simle cam chnage can afftect the header designed
Occasionally you can get a good middle of the road header that will compliment a wide variety of engines but there is muhc more power to be gained from one designed for a specific combination
Old Nov 16, 2004 | 12:01 PM
Doctor CorteZ's Avatar
Default Re: header difference??? (SHystrdyGSRtdy)
with headers its obvious , you get what you pay for.
wrong forum also.
CooBlueDAB
13
Jan 3, 2007 09:04 AM
boosted94teggy
Sep 19, 2005 11:25 PM
blu3g
May 25, 2005 02:26 PM
cichlid
Mar 22, 2003 12:51 PM
