Alternator keeps frying ? ? ? ?
Old Dec 26, 2001 | 12:41 PM
OPTIMUS's Avatar
New User
Default Alternator keeps frying ? ? ? ?
I have a 2000 HONDA CIVIC with 21k miles.
I have a Jackson Racing Supercharger that was installed and the individual that installed it said that the wiring under the hood in the area of the supercharger had to be rewired.
There is a part on my alternator made of plastic that is melting causing the connection to the alternator and the wire to be lost. The alternator has been replaced twice now with the same part going bad. Does anyone have any ideas why this occurs.
HONDA hasn't voided my warranty but will not warranty this repair.
Old Dec 26, 2001 | 02:06 PM
Spade's Avatar
Default Re: Alternator keeps frying ? ? ? ? (HYBRID MOTOR)
Edit: Plastic melting.......casing on the alt itself?
[Modified by Spade, 3:06 PM 12/26/2001]
Old Dec 26, 2001 | 04:51 PM
tooqwik1's Avatar
chek the ground sounds like its straining nd overheating
Old Dec 27, 2001 | 11:20 AM
OPTIMUS's Avatar
New User
Default Re: Alternator keeps frying ? ? ? ? (tooqwik1)
There is an actual plastic piece that is connected to the alternator itself on the bottom end of it. This piece keeps melting.
Thank you tooqwik1 for your suggesstion. I was offered this advise by someone else that it is not getting enough ground. How can I increase the amount of ground so I can get rid of this problem?
Old Dec 27, 2001 | 12:04 PM
AutoXsi2000's Avatar
Did you check to see if that part was getting good air circulation? It could also be that the supercharger is putting more strain or spining too fast the belt and pully. The result is overheating alternator and heat dissipating near the plastic. I would email Jackson Racing for any pros and cons.
vgurra
Honda Civic (2001 - 2005)
Jun 22, 2015 03:38 AM
freeofparanoia
Oct 20, 2003 08:51 PM
OPTIMUS
Dec 27, 2001 11:29 AM
