cam gears on, but crazy weird alignment
Old Nov 13, 2004 | 04:53 PM
b18-c-rx's Avatar
Default cam gears on, but crazy weird alignment Help ASAP
So here's the story:
I found the punch (5mm) hole and set it up so that it would hold the shafts. This should mean that the camshaft is how it should be at TDC, am i not correct?
The problem is, the notches on my cam gears are about 2-3 degrees apart (calculated this w/ measurements). These are supposed to be aligned at TDC, correct?
Should I go ahead and adjust my cam gears (Skunk2s) to make the marks align?
Old Nov 13, 2004 | 05:16 PM
b18-c-rx's Avatar
Default Re: cam gears on, but crazy weird alignment Help ASAP (b18-c-rx)
bump for response asap!
Old Nov 13, 2004 | 05:26 PM
mike_belben@yahoo.com's Avatar
From: not riding any bandwagons in, massachusetts, usa
are the keyways both pointing up?
Old Nov 13, 2004 | 05:50 PM
RCautoworks's Avatar
Default Re: (mike_belben@yahoo.com)
Do a search on skunk2 cam gears, if I remember correctly they do not line up that good. Anyways if you set the old cam gears at tdc and did not move them at all, put the skunk2 cam gears at tdc.
ahobbs
Texas -OK -LA (Sales)
Oct 13, 2009 02:32 PM
m R g S r
Feb 24, 2006 02:05 PM
B18Redline
Nov 30, 2004 11:19 AM
hon
Jul 22, 2004 09:52 PM
