Skunk 2, stage 2 cams.
Old Nov 13, 2004 | 03:19 PM
HamiltonRex's Avatar
Default Skunk 2, stage 2 cams.
Can stock 2ndt gen b16 valvetrain hold them?
How do they idle?
How will they preform over b17 cams on a poormans itr running 10.2:1 CR?
Or would some toda's or Jun's be better? My cams are killing it.
Modified by HamiltonRex at 4:37 PM 11/13/2004
Old Nov 13, 2004 | 04:25 PM
JaymieTypeR's Avatar
Default Re: Skunk 2, stage 2 cams. (HamiltonRex)
the skunk stage 2 cams will be overkill for you stock vavletrain.
and the cams will not preform to the full potential on that low a compression.
unless you wanna get new high compression pistons and a new valvetrain i would not suggest those cams.
i would go with something along the lines of civic type r cams.
Old Nov 14, 2004 | 12:08 AM
98itr0448's Avatar
Default Re: Skunk 2, stage 2 cams. (JaymieTypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JaymieTypeR &raquo;</TD></TR><TR><TD CLASS="quote">the skunk stage 2 cams will be overkill for you stock vavletrain.
You need at least 11:1:1 compression to see any results out of Stage II's. Ideally you would want close to 12:1:1. Get some itr/ctr and you'll be good to go. You could also run some stage I's and get a two layer head gasket to up the compression some. As long as you stay at factory redline you can run them on your stock valve train.
Old Nov 14, 2004 | 01:12 PM
Default Re: Skunk 2, stage 2 cams. (LSVtecITR)
thanks alot.
Old Nov 24, 2004 | 01:31 AM
Chubz's Avatar
how woulf those cams do on a jdm 11:1 itr motor?
Old Nov 24, 2004 | 07:01 PM
UncleD's Avatar
Default Re: Skunk 2, stage 2 cams. (Chubzilla)
Listen to those first two cats and what they said, they know what they are talking about. To good information. Skunk 2 stg.2's will need 12:1 to run to there potential. Even though they are "just" a "stage 2," they are very aggresive. With a compression around 11.1 I might suggest a skunk stg.1, CTR, BC 3's, something kinda mild like that. Ups to Jaymie and LSVtec....
Old Nov 25, 2004 | 02:13 AM
Chubz's Avatar
Default Re: Skunk 2, stage 2 cams. (clean rice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice &raquo;</TD></TR><TR><TD CLASS="quote">Listen to those first two cats and what they said, they know what they are talking about. To good information. Skunk 2 stg.2's will need 12:1 to run to there potential. Even though they are "just" a "stage 2," they are very aggresive. With a compression around 11.1 I might suggest a skunk stg.1, CTR, BC 3's, something kinda mild like that. Ups to Jaymie and LSVtec....</TD></TR></TABLE>
do the buddy club 3s require different valvesprings?
Old Nov 25, 2004 | 03:12 AM
allm0t0rsir's Avatar
yup
Old Nov 27, 2004 | 03:20 PM
UncleD's Avatar
Default Re: Skunk 2, stage 2 cams. (allm0t0rsir)
It's almost safe to say that if you plan on running anything bigger than a type r cam that you will need to run different springs, with the exception of a few. But you really should replace the springs, they really don't cost too much anyways..
g23cg5
Nov 15, 2013 04:58 AM
Ruben19
Jan 24, 2006 07:25 PM
bugster
Jan 28, 2005 04:53 PM
PyR01-0347
Sep 21, 2003 04:07 AM
2000GSR
Mar 17, 2003 12:19 PM
