Need help with B16A wiring into a CRX Si...
ok my friend has a crx si, and he has the whole entire front clip from a CRX SiR. he's swapping the B16 from the clip into his car and needs to know which harness to use.
He will use the harness from the USDM car. You do not need to swap harness's, infact you don't want to. You will have to add a few wires for the second O2 sensor/vtec solenoid/vtec pressure sensor and I think that's it.
if you use the search function both on honda tech and google.com then you will find ALL the answers you need.
From: I told you to wait in the truck in Texas, United States
If you look in the FAQ section at the top of this forum,
There are several links provided that might aid you in your quest..
Hondzas
Jan 20, 2004 10:55 AM
