FS: 93 Civic 4DR. Ex AT
1993 Civic 4 door EX, Automatic, 1 owner car with original window sticker, black exterior color with gray interior, power windows, power locks, cruise control, power mirrors, 4 wheel abs, 4 wheel disc brakes, power moon roof, optional factory alloy wheels, front and rear stabilizer bars, cold air conditioning. Tires are in good condition. Has new brakes on all 4 corners. The car has 180,000 miles. Motor was just rebuilt by me with all OEM Honda parts.
The internal engine parts that are new are as follows (all are OEM Honda parts it's nice to get parts at employee cost
): main bearings, thrust washers, rod bearings, rings, head gasket, and oil pan gasket.
These are the external parts that are new: Air filter, brake fluid, both axles, antifreeze, water pump, timing belt, thermostat, valve cover gasket, cam seal, crank seal, rear main seal, power steering belt, alternator belt, air conditioning belt, distributor cap, rotor button, plugs, fuel filter, spark plug wires, automatic transmission fluid, battery, main relay, and brake light switch.
The car has normal wear and tear. It is in great condition for being 11 years old. Located in Nashville Tennessee. Title in hand. $3,850 O.B.O. Please see pictures below. JHMEH9693PS003335
http://www.we-todd-did-racing....D.jpg
Sorry about the big pictures
Modified by turbodav at 5:11 PM 11/14/2004
): main bearings, thrust washers, rod bearings, rings, head gasket, and oil pan gasket. These are the external parts that are new: Air filter, brake fluid, both axles, antifreeze, water pump, timing belt, thermostat, valve cover gasket, cam seal, crank seal, rear main seal, power steering belt, alternator belt, air conditioning belt, distributor cap, rotor button, plugs, fuel filter, spark plug wires, automatic transmission fluid, battery, main relay, and brake light switch.
Your
CARFAX
Vehicle History Report
Since its establishment as an independent company in 1986, CARFAX has
collected the largest vehicle history database in North America. This
database currently includes over 3 billion records from thousands of
public and private sources.
A CARFAX Vehicle History Report is based only on information supplied to
CARFAX. Other information about this vehicle, including problems, may not
have been reported to CARFAX. Use this report as one important tool,
along with a vehicle inspection and test drive, to make a better decision
about your next used car.
CARFAX TALKING CAR (TM)
The story of this 1993 HONDA CIVIC EX/EX-V (JHMEH9693PS003335)
according to our interpretation of the information reported to CARFAX:
* This sedan has had 2 owners and was owned in Illinois and
Tennessee. The first title for this sedan was reported to CARFAX by
an Illinois DMV in 1992.
* It has had no minor or moderate accidents reported to CARFAX.
* It has had no DMV-reported total loss events, like a major
accident, fire or flood.
* It has not been reported by a DMV as having an Exceeds
Mechanical Limits or Not Actual Mileage title.
* It has a consistent mileage history with no indication of an
odometer rollback. The last odometer reading, reported on
11/04/2002, was 153,000 miles.
* It was not reported to a DMV as a Manufacturer Buyback (LEMON).
* Go to the Detailed Vehicle History for the complete history and
a glossary of terms.
CARFAX VEHICLE HISTORY REPORT SUMMARY
** Good News - Vehicle qualifies for the CARFAX Buyback Guarantee! No
severe problems (major accidents, fire, flood damage, major odometer
problems or lemon history) were ever reported by a Department of Motor
Vehicles (DMV) for this 1993 HONDA CIVIC EX/EX-V (JHMEH9693PS003335). If
you find that any of these severe problems were reported by a DMV and not
included in this report, CARFAX will buy this vehicle back.
You MUST REGISTER to activate this free guarantee!
http://www.carfax.com/guarante...U.EDU
Sect.# Section Name Section Results
1. ACCIDENT CHECK
Total Loss Check NO Severe Accident or Total Loss Event
Reported to DMV - Buyback Guarantee! Other Accident Indicators NO
Accident Indicator Found
2. MILEAGE ACCURACY CHECK
Truth-In-Mileage Check NO Odometer Problems Reported to DMV -
Buyback Guarantee! Odometer Rollback Check No Potential Odometer
Rollback Found Mileage Consistency Check NO Inconsistent Odometer
Reading Found
3. LEMON CHECK(R) NO Mfr. Buyback Reported to DMV - Buyback
Guarantee!
4. OWNERSHIP CHECK
Number of owners 2 Estimated Owner(s)
Type of owners Checked 8 Types of Vehicle Registrations
5. RECALL CHECK HONDA does not report recalls to CARFAX
6. WARRANTY CHECK No Data Reported to CARFAX
DETAILED VEHICLE HISTORY 8 HISTORY RECORDS REPORTED
VEHICLE DESCRIPTION
Year/Make/Model: 1993 HONDA CIVIC EX/EX-V
Body Style: SEDAN 4 DR
Engine: 1.6L L4 MULTIPOINT FI
Fuel: GASOLINE
Driveline: FRONT WHEEL DRIVE
Safety Equipment:
4 wheel ABS, Driver front air bag/passenger side active (manual) belt
Standard Equipment:
Power Windows, Power Steering, AM / FM Cassette, Power Brakes, Power sun
/ moon roof, Tilt Wheel, 6-digit Odometer
SECTION 1 ACCIDENT CHECK
TOTAL LOSS CHECK:
* GOOD NEWS! No severe damage events were ever reported by a DMV for this
1993 HONDA CIVIC EX/EX-V (JHMEH9693PS003335). If you find that
any of the following severe problems were reported by a DMV and not
You must register to activate this free guarantee!
*OK* Salvage Title *OK* Loss Due to Fire Title *OK*
Junk Title *OK* Flood Damage Title
*OK* Rebuilt/Reconstructed Title *OK* Hail Damage Title
*OK* Dismantled Title *OK* Canadian Total Loss
OTHER ACCIDENT INDICATORS:
This 1993 HONDA CIVIC EX/EX-V (JHMEH9693PS003335) had no accident
indicators reported to CARFAX from its sources. This section checks for
accidents and/or related damage reported from many public and private
sources. Not all accidents are reported to CARFAX. A vehicle inspection
completed by your dealer or professional mechanic is recommended.
Salvage Auction Record..............> NO Salvage Auction Record Reported
Fire Damage Record..................> NO Fire Damage Record Reported
Crash Test Vehicle Record...........> NO Crash Test Vehicle Record
Reported Airbag Deployment Record............> NO Airbag Deployment
Record Reported Damage Disclosure Record............> NO Damage
Disclosure Record Reported Police Accident Record..............> NO
Police Accident Record Reported
SECTION 2 MILEAGE ACCURACY CHECK
TRUTH-IN-MILEAGE CHECK:
* RESULT: GOOD NEWS!
No major odometer problems were ever reported by a DMV under the
Truth-In-Mileage Act for this 1993 HONDA CIVIC EX/EX-V
(JHMEH9693PS003335). If you find that any of the following odometer
problems were
reported by a DMV and not included in this report, CARFAX will
buy this vehicle back. You must register to activate this free guarantee!
*OK* Not Actual Mileage Title - issued by DMV when the owner discloses
mileage fraud or a broken odometer.
*OK* Exceeds Mechanical Limits Title - issued by DMV when the owner
discloses an odometer rollover.
ODOMETER ROLLBACK CHECK:
CARFAX found no odometer rollbacks for this
Rollbacks reported in this section originate from readings
collected by a DMV or other verifiable source.
MILEAGE CONSISTENCY CHECK:
CARFAX found no inconsistent odometer readings in the mileage history of
Date: Mileage:
12/16/1992 84
05/13/1993 8,000
12/29/1997 82,540
07/14/1998 90,000
03/02/1999 102,841
11/09/2001 130,000
11/04/2002 153,000
SECTION 3 LEMON CHECK
* GOOD NEWS!
No manufacturer buyback was ever reported by a DMV for this
1993 HONDA CIVIC EX/EX-V (JHMEH9693PS003335). If you find that a
manufacturer buyback was reported by a DMV and not included in this
SECTION 4 OWNERSHIP CHECK
Ownership History:
CARFAX estimates that this 1993 HONDA CIVIC EX/EX-V (JHMEH9693PS003335)
had 2 owner(s). CARFAX analyzed this vehicle's title history and other
supporting events to identify potential ownership transfers. In
compliance with the U.S. privacy laws, CARFAX does not collect or report
owner names or addresses.
Estimated Owners: Date: Location:
1st owner 12/16/1992 Illinois
2nd owner Not Reported
CARFAX Advisor(TM)
The cost of ownership varies by vehicle. Go to Edmunds.com to check the
recommended service schedule and estimated costs for this vehicle.
http://applications.edmunds.co...27615
Types of Owners:
This 1993 HONDA CIVIC EX/EX-V (JHMEH9693PS003335) was
checked for 8 types of registrations.
Personal Use Registration............> NO Personal Use Registration
Reported Lease Registration..................> NO Lease Registration
Reported Rental Registration.................> NO Rental Registration
Reported Taxi Registration...................> NO Taxi Registration
Reported Fleet Registration..................> NO Fleet Registration
Reported Commercial Registration.............> NO Commercial
Registration Reported Non-Profit Registration.............> NO
Non-Profit Registration Reported Built to Non U.S. Standards Record..>
NO Built to Non U.S. Standards Record Reported
SECTION 5 RECALL CHECK
HONDA does not report recall information for specific vehicles to CARFAX.
Refer to the CARFAX SAFETY & RELIABILITY REPORT (tm) for recalls
issued by the National Highway Traffic Safety Association (NHTSA)
for the 1993 HONDA CIVIC EX/EX-V.
You can also contact an authorized dealership or HONDA at 1-800-999-1009
or at http://www.honda2000.com to find out if this 1993 HONDA CIVIC EX/EX-V
(JHMEH9693PS003335) still has recalls that require repair.
SECTION 6 WARRANTY CALCULATOR
CARFAX cannot calculate the remaining coverage for this
1993 HONDA CIVIC EX/EX-V (JHMEH9693PS003335) because no
original manufacturer warranty information was reported
to CARFAX from its source.
Estimated start date of warranty: 12/16/1992 Last
reading reported on 11/04/2002: 153,000 miles
Today's Date: November 14, 2004
Basic Original Warranty:
No data reported to CARFAX
Drivetrain Original Warranty:
Emissions Original Warranty:
Corrosion Original Warranty:
Transferable Original Warranty:
Roadside Assistance Original Warranty:
Safety Belt & Inflatable Restraint Original Warranty:
Specific Components:
CARFAX Warranty Check provides an estimate of this vehicle's
remaining warranty coverage. It does not take into account some
vehicle history events. For example, major accidents resulting
in Salvage or Junk titles that may void the original
manufacturer warranty or ownership transfers that may decrease
warranty coverage. This warranty information is only valid for vehicles
manufactured for sale in the US. Complete warranty coverage information is
available for this vehicle at the
HONDA web site.
CARFAX searched more than 3 billion records from over 5,300 sources and
found 8 record(s) for this 1993 HONDA CIVIC EX/EX-V (JHMEH9693PS003335).
Date: 12/16/1992
Odometer Reading: 84
Information Source:
Illinois
Motor Vehicle Dept.
Bloomington, IL
Title #H6961924
General Comments:
Title issued or updated
First owner reported
Loan or lien reported
Date: 05/13/1993
Odometer Reading: 8,000
Information Source:
Illinois
Motor Vehicle Dept.
Bloomington, IL
Title #E7892014
General Comments:
Date: 12/29/1997
Odometer Reading: 82,540
Information Source:
Illinois
Motor Vehicle Dept.
Bloomington, IL
Title #T7363777044
General Comments:
Duplicate title issued
Date: 07/14/1998
Odometer Reading: 90,000
Information Source:
Illinois
Motor Vehicle Dept.
Bloomington, IL
Title #T8195560050
General Comments:
Date: 03/02/1999
Odometer Reading: 102,841
Information Source:
Illinois
Motor Vehicle Dept.
Bloomington, IL
Title #T9061106042
General Comments:
Date: 11/09/2001
Odometer Reading: 130,000
Information Source:
Tennessee
Inspection Station
General Comments:
Passed emissions inspection
Date: 12/07/2001
Information Source:
Tennessee
Motor Vehicle Dept.
Spring Hill, TN
Title #64132425
General Comments:
Registration issued or renewed
Title or registration issued
New owner reported
Date: 11/04/2002
Odometer Reading: 153,000
Information Source:
Tennessee
Inspection Station
General Comments:
NOTE: You have significantly reduced your risk of purchasing a vehicle
with a hidden problem. However, CARFAX has not inspected this vehicle.
There could be other potential problems with this vehicle that have not
been reported to CARFAX. CARFAX recommends a vehicle inspection by a
professional mechanic.
NOTE: Not all titles issued represent a change in vehicle ownership. For
example, a title could be issued to reflect an address change or
correction.
Register your FREE CARFAX Buyback Guarantee Today!
Your
CARFAX
1. ACCIDENT CHECK
Reading Found
Guarantee!
4. OWNERSHIP CHECK
VEHICLE DESCRIPTION
Fuel: GASOLINE
Safety Equipment:
Standard Equipment:
TOTAL LOSS CHECK:
problems were
Date: Mileage:
12/16/1992 84
05/13/1993 8,000
12/29/1997 82,540
07/14/1998 90,000
03/02/1999 102,841
11/09/2001 130,000
11/04/2002 153,000
* GOOD NEWS!
Ownership History:
CARFAX Advisor(TM)
Types of Owners:
HONDA web site.
Date: 12/16/1992
Information Source:
Illinois
Motor Vehicle Dept.
Bloomington, IL
Title #H6961924
General Comments:
Date: 05/13/1993
Information Source:
Illinois
Motor Vehicle Dept.
Bloomington, IL
Title #E7892014
General Comments:
Date: 12/29/1997
Information Source:
Illinois
Motor Vehicle Dept.
Bloomington, IL
Title #T7363777044
General Comments:
Date: 07/14/1998
Information Source:
Illinois
Motor Vehicle Dept.
Bloomington, IL
Title #T8195560050
General Comments:
Date: 03/02/1999
Information Source:
Illinois
Motor Vehicle Dept.
Bloomington, IL
Title #T9061106042
General Comments:
Date: 11/09/2001
Information Source:
Tennessee
Inspection Station
General Comments:
Date: 12/07/2001
Information Source:
Tennessee
Motor Vehicle Dept.
Spring Hill, TN
Title #64132425
General Comments:
New owner reported
Date: 11/04/2002
Information Source:
Tennessee
Inspection Station
General Comments:
correction.
