how do you guys with AEM CAI clean your filters (get to the filter)
Old Dec 26, 2001 | 10:08 AM
6SPD_EK's Avatar
Default how do you guys with AEM CAI clean your filters (get to the filter)
please letme know - I have not clean/changed it in soooo many thousands of miles, I need to know how to get to it without taking off the front bumper
Old Dec 26, 2001 | 10:14 AM
ingrate's Avatar
25 Year Member
Default Re: how do you guys with AEM CAI clean your filters (2000-4DRGSR)
remove that black plastic splashguard under the right fender to get access. i'd suggest using K&N's filter cleaner thing
Old Dec 26, 2001 | 08:41 PM
vteg's Avatar
New User
Removing the tire makes it easier also.
Old Dec 26, 2001 | 09:41 PM
B2FiNiTY's Avatar
Default Re: how do you guys with AEM CAI clean your filters (vteg)
It does make it easier but is unnecessary. Just turn your wheel to the right. Just remove the fender lining and you can access the filter.
Old Dec 26, 2001 | 09:46 PM
strils's Avatar
i get to mine from underneath by pulling down the splash gaurd then take it off and use the K&N filter re-charger kit
Old Jan 22, 2002 | 02:59 AM
SoCal ITR's Avatar
Default Re: how do you guys with AEM CAI clean your filters (strils)
How often do you guys clean it?
Old Jan 22, 2002 | 04:05 AM
VTechie's Avatar
Default Re: how do you guys with AEM CAI clean your filters (SoCal ITR)
About as often as I get a tune-up. Maybe every 2-3 oil changes?
Old Jan 22, 2002 | 05:52 AM
BoM's Avatar
BoM
Default Re: how do you guys with AEM CAI clean your filters (VTechie)
4 times a year
once every season
make sure you reoil that piece or your going to suck up water
1 1/2 years and still no hydrolock
i dont' have a bypass valve too...careful driving and maintenence
Old Jan 22, 2002 | 12:02 PM
tonydatyga's Avatar
Default Re: how do you guys with AEM CAI clean your filters (BoM)
4 times a year
once every season
and common sense
Old Jan 22, 2002 | 12:47 PM
smeister's Avatar
Default Re: how do you guys with AEM CAI clean your filters (tonydatyga)
just take the filter off...well take of the splash guard then undo the filter and clean it and mount it back on...it's not that difficult
Old Jan 22, 2002 | 02:51 PM
FourDoorGSR's Avatar
Dont forget to dust off the small pebbles and rocks that are imbedded on there. I found using a soft detailers brush that I had before does wonders before spraying it with the K&N filter cleaner
Old Jan 22, 2002 | 03:02 PM
Jmm0056's Avatar
Default Re: how do you guys with AEM CAI clean your filters (FourDoorGSR)
i would say that form under the car would be the easiest just 2 bolts to remove and its very easy to get to.......................that reminds me that mines due for a cleaning too
Old Jan 22, 2002 | 03:07 PM
Comptech98GSR's Avatar
Default Re: how do you guys with AEM CAI clean your filters (Jmm0056)
hell yea yours is due, but don't clean it till after we race
Old Jan 22, 2002 | 03:08 PM
neo1z's Avatar
how do u actually clean it - i have an iceman, but im sure its the same concept. you just wipe it off, wa? what?
Old Jan 22, 2002 | 03:26 PM
Default Re: how do you guys with AEM CAI clean your filters (neo1z)
The K&N filter charger kit has all the isntructions. But the short of it is:
1) remove filter
2) dust off loose dirt
3) spray with k&n filter cleaner
4) let it soak for approx 15mins
5) gently rinse of the cleaner from inside the filter out so the rocks/pebbles dont get stuck in the filter element
6) IMPORTANT AIR DRY no blow drying
7) spray some new k&n filter recharger oil (make sure u cover every inch)
8) re-install
JDM Accord 510
Nov 5, 2004 03:54 PM
eluder33
Aug 17, 2004 09:05 PM
B00ST2nR
Sep 22, 2002 06:23 PM
hYpE-R-29
Apr 7, 2002 03:21 PM
VTEConly
Jul 9, 2001 01:17 PM
