What is the stock bobweight for a b18c
Old Nov 12, 2004 | 10:51 PM
Mach1's Avatar
Default What is the stock bobweight for a b18c
I am curious to what the stock bobweight is for a b18c vs the bobweight of a aftermarket piston and h-beam rod combo.
Old Nov 13, 2004 | 12:10 PM
Mach1's Avatar
Default Re: What is the stock bobweight for a b18c (Mach1)
ttt
Old Nov 16, 2004 | 12:04 PM
vtecmissle's Avatar
i dont believe they use bobweight as a rule because they are an inline engine and internally balanced
Old Nov 17, 2004 | 12:28 PM
Mach1's Avatar
Default Re: What is the stock bobweight for a b18c (vtecmissle)
bobweight is the weight of the rod, rod bearings, rodbolts, piston, pin, pin locks and the rings so it would apply to any std engine, I would like to compare a stock rod piston combo to a aftermarket hbeam and piston combo weight wise.
Old Nov 17, 2004 | 12:40 PM
drdisco69's Avatar
Most manufacturers publish the weight of their stuff, and I'm sure someone has weighed the stock stuff. Since the bearings, wrist pins and all that will be the same weight, you can compare the weights of the rods and pistons only.
Old Nov 17, 2004 | 12:44 PM
Mach1's Avatar
Default Re: What is the stock bobweight for a b18c (drdisco69)
Hrmm hopefully someone will post the stock stuffs weight, pins can vary quite a bit in weight but thats getting kinda picky, are hondas pins pressed into the rod from the factory or are they full floating
Old Nov 17, 2004 | 12:53 PM
drdisco69's Avatar
Most are pressed.
lsvtecek18
Oct 19, 2006 05:47 PM
chris2000
Oct 13, 2006 05:54 PM
leadfoot78
Jan 20, 2004 04:28 PM
NoLipRacen
Dec 26, 2003 12:48 PM
