car sterio in the house?
Old Nov 12, 2004 | 08:50 PM
A L I A S's Avatar
Default car sterio in the house?
basicaly what i want to know is how can i hook my car sterio up for home use? or if its even possible? (SEARCHED)
Old Nov 12, 2004 | 10:36 PM
was
Default Re: car sterio in the house? (bolivian bistro)
uh no... car audio **** is setup for 4 ohms and less.... home audio is always 8ohms or greater....
plus if it did work you would need a big *** power converter
Old Nov 13, 2004 | 04:24 AM
bassisliffe's Avatar
Default Re: car sterio in the house? (Prince of Darkness)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prince of Darkness &raquo;</TD></TR><TR><TD CLASS="quote">uh no... car audio **** is setup for 4 ohms and less.... home audio is always 8ohms or greater....
plus if it did work you would need a big *** power converter </TD></TR></TABLE>
you are a total ******* idiot, me and alot of people i know do it with great success, any power inverter will suffice
dc to ac, simple as that
Old Nov 13, 2004 | 06:09 AM
scrolanky's Avatar
Default Re: car sterio in the house? (bassisliffe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bassisliffe &raquo;</TD></TR><TR><TD CLASS="quote">
dc to ac, simple as that</TD></TR></TABLE>
I think the pot is calling the kettle black here
Old Nov 13, 2004 | 08:10 AM
EBP_SI's Avatar
Default Re: car sterio in the house? (scrolanky)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">uh no... car audio **** is setup for 4 ohms and less.... home audio is always 8ohms or greater....
where did you come up with that BS?? home audio is not always 8ohms or greater. i have 4ohm speakers.
if home audio is 8ohms and you hook up some 4ohm drivers, please explain to us what is going to happen.
Old Nov 13, 2004 | 08:54 AM
GSteg's Avatar
Default Re: car sterio in the house? (EBP_SI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EBP_SI &raquo;</TD></TR><TR><TD CLASS="quote">
if home audio is 8ohms and you hook up some 4ohm drivers, please explain to us what is going to happen.</TD></TR></TABLE>
ooOOOOoo!!! pick me pick me!!!
Old Nov 13, 2004 | 09:02 AM
EBP_SI's Avatar
Default Re: car sterio in the house? (GSteg)
lol...go ahead son..
Old Nov 13, 2004 | 09:09 AM
GSteg's Avatar
Canada will invade the US.
Old Nov 13, 2004 | 09:16 AM
EBP_SI's Avatar
Default Re: (GSteg)
lol...'m suprised the bush hasn't invaded canada because we dont support the war.
Old Nov 13, 2004 | 02:28 PM
GSteg's Avatar
ok back topic. lol..
one time i connected my dual 4ohm idmax to a 4ohm stable receiver and nothing happened, as in nothing bad happens.
likewise, impedence changes when your change frequency so it's never always X ohm.
how long u run the amp and how loud will affect the life of the amp or receiver.
car audio in homes. defintely doable.
come to think of it, i need a plate amp for my sub. $30 for a 25w is good enough for me. buahahha
Old Nov 14, 2004 | 06:40 AM
Default Re: (GSteg)
i hooked up my speakers from my car on a home stereo yesterday, no invasion yet
Old Nov 14, 2004 | 08:54 AM
EBP_SI's Avatar
Default Re: (bassisliffe)
i blew my CAV-180 when i connected my type-x components to it and played it loud. guess they dont like 700W of real power. they sounded increadibly smooth while they were playing though.
Old Nov 14, 2004 | 10:20 AM
zumiez007's Avatar
Default Re: (EBP_SI)
but how do you hook up say an amp or headunit to a standard 110 outlet? I've read something about using computer power supplies, but they need a lot of ampage.
Old Nov 14, 2004 | 11:38 AM
GSteg's Avatar
the only thing the PC PS was good for was the headnuit. othe than that, no amp. lol. Even then, the headunit can't be turned up high unless the PS has loads of ampere.
believe me, i tried. Much better getting an DC to AC convertor.
Old Nov 14, 2004 | 12:05 PM
A L I A S's Avatar
Default Re: (GSteg)
so as long as you get this dc to ac converter you can jam safely in your house?
Old Nov 14, 2004 | 12:26 PM
Default Re: (bolivian bistro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bolivian bistro &raquo;</TD></TR><TR><TD CLASS="quote">so as long as you get this dc to ac converter you can jam safely in your house?</TD></TR></TABLE>
i wouldn't say 'safely' depending on what you hVE
i hookked up my eminence aplha and 2 bullet tweets and it surrrr ea aint safe! AROUND HERE!
Old Nov 14, 2004 | 12:29 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EBP_SI &raquo;</TD></TR><TR><TD CLASS="quote">i blew my CAV-180 when i connected my type-x components to it and played it loud. guess they dont like 700W of real power. they sounded increadibly smooth while they were playing though.</TD></TR></TABLE>
what has 700watts of real power?
your components?/?
Old Nov 14, 2004 | 01:58 PM
EBP_SI's Avatar
your components?/? </TD></TR></TABLE>
my amp, using 4 x360W channels to bi-amp my components
Old Nov 14, 2004 | 02:00 PM
nsxxtreme's Avatar
Default Re: (GSteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSteg &raquo;</TD></TR><TR><TD CLASS="quote">the only thing the PC PS was good for was the headnuit. othe than that, no amp. lol. Even then, the headunit can't be turned up high unless the PS has loads of ampere.
believe me, i tried. Much better getting an DC to AC convertor.</TD></TR></TABLE>
Why would you use a DC to AC convertor? Do you mean AC to DC.
The 12 volt line on a PC power supply is very weak.
In order to run any 12 volt system that use a lot of current the AC to DC convertor would cost more than a nice home reciever. The only cheap way is to hook a battery up and a charger. Kind of ghetto riging it though.
Most home recievers are built for 8 ohm speakers. Most home recievers will shut down at high volume when trying to play 4 ohm speakers. Some home recievers have a switch on the back for 4 ohm loads.
So yes its possible but seems kinda silly.
Did you recieve your amp?
Old Nov 14, 2004 | 02:01 PM
A L I A S's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bassisliffe &raquo;</TD></TR><TR><TD CLASS="quote">i wouldn't say 'safely' depending on what you hVE
i hookked up my eminence aplha and 2 bullet tweets and it surrrr ea aint safe! AROUND HERE! </TD></TR></TABLE>
i have 2 jl's and an mtx (all 12" ) on a dual amp set up audiobahn mids and monster cables.....im guessing this is WAYYYYY to strong to be powered by my outlet in the wall
Old Nov 14, 2004 | 03:03 PM
EBP_SI's Avatar
Default Re: (nsxxtreme)
with all the work it would take to do this, why not jsut sell what you have and invest in a home audio system.
Old Nov 14, 2004 | 04:38 PM
GSteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxxtreme &raquo;</TD></TR><TR><TD CLASS="quote">Why would you use a DC to AC convertor? Do you mean AC to DC.
oh yea ur right. lol. I was thinking the Headunit connecting to the wall outlet. hahaha
Old Nov 14, 2004 | 06:29 PM
A L I A S's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EBP_SI &raquo;</TD></TR><TR><TD CLASS="quote">with all the work it would take to do this, why not jsut sell what you have and invest in a home audio system. </TD></TR></TABLE>
well i thought it would be tyte to have the subbs in my room working instead of in the basement collecting dust....
Old Nov 15, 2004 | 10:37 AM
zumiez007's Avatar
Poor college student. Still want a car stereo for the long trip home.
Old Nov 15, 2004 | 01:46 PM
EBP_SI's Avatar
well i thought it would be tyte to have the subbs in my room working instead of in the basement collecting dust....</TD></TR></TABLE>
riiight. so again....instead of having it collecting dust in the basement, sell it and buy a home sub.
