Need Help!!! Block Related with plugs on a B18A
Got my block back from resleeving by GE and noticed it didn't have the plugs in the transmission and t-belt side of my motor, well GE hooked me up with replacements but I have no idea what to torque these to. Its a B18A but noticed B18B's use the same style plugs. The Helms has nothing about this either, any help you can offer will be appreciated.
Plugs:
T-Belt Side:
Trans Side:
Plugs:
T-Belt Side:
Trans Side:
You might be able to use the washer that acura/honda provides for the front coolant drainage plug.
Honda/Acura part number 90401-pr4-000
Does anyone happen to know if part#3 in this image is the same as the B18/B16's oil gulley plugs and if so can I use part 17 as the washer I'm missing.?Every single pic I find doesn't list it as a seperate part.
This is an image from a 03 SI with the K block.
Ok it is the same washer as said above. PN# 90401-PR4-000 so would assume the parts listed above would be correct. Yippee finally have this issue solved. Going to order parts tomorrow. Thanks again...
vanny_david
Jul 14, 2009 03:25 PM
