whats the secret for the 'cut and weld' tranny mount-b series
Old Dec 26, 2001 | 07:25 AM
BigBlockCRX's Avatar
New User
Default whats the secret for the 'cut and weld' tranny mount-b series
I want to cut and re weld the tranny mount for my b16a into a 89 crx..
ok so I use an LS drivers side mount,
then flip the rear mount..
then use the stock teg pass mount and reweld the brackets to the frame..
use 90-93 teg axels too, correct?
or.. 88-89 teg axels
thanks
Old Dec 26, 2001 | 07:27 AM
Phatwhippin_CRX's Avatar
Default Re: whats the secret for the 'cut and weld' tranny mount-b series (BigBlockCRX)
The trick is... dont do it. Seriously.... get mounts man, you dont want that **** breaking, trust me...
Old Dec 26, 2001 | 07:29 AM
EP3_05's Avatar
Default Re: whats the secret for the 'cut and weld' tranny mount-b series (Phatwhippin_CRX)
I just got my hasport mount kit and they are sweet looking. Just get the mount kit and save yourself some headaches.
Old Dec 26, 2001 | 08:25 AM
crux131's Avatar
Default Re: whats the secret for the 'cut and weld' tranny mount-b series (91civic)
I don't see why it would break if welded correctly, but it just doesn't seem worth the headaces.
Just get a Hasport, or an HCP mount kit.
Old Dec 26, 2001 | 09:47 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: whats the secret for the 'cut and weld' tranny mount-b series (crux131)
your welding to SHEET METAL.
Forget it and get the HASport mounts.
Old Dec 26, 2001 | 04:52 PM
Giuseppe's Avatar
Default Re: whats the secret for the 'cut and weld' tranny mount-b series (Mista Bone)
broken axles, broken mounts...why risk it...
get
HASPort mounts..
Old Dec 26, 2001 | 08:33 PM
nickgomez's Avatar
Default HASPORT
Use Hasport mounts please. My opinion? Don't do all that weld-in stuff unless its a banger and Hasport mounts are too expensive for you.
Old Dec 29, 2001 | 11:21 PM
bubblebackinSI's Avatar
first of all ge some mounts. i got place racing mounts and i think there the ****. Second use 90-93 integra axles. last but not least go to a junkyard and get a 93 rear bracket mount for the back of the motor.
Old Dec 30, 2001 | 04:36 PM
New User
Default Re: whats the secret for the 'cut and weld' tranny mount-b series (bubblebackinSI)
you guys kill me..
I have hasport mounts.. I have two crx's.. and two b series swaps.. I just wanted to try it to save a little money.. 500 would mean pistons for the b20 or even cams..
I know you guys have done this, whats the secret? like axels and stuff
Old Dec 30, 2001 | 06:41 PM
ssdEF9's Avatar
i had a swap done more than a year ago and when i saw the mounts they look like stock mounts, i showed it to a friend he says they are old integra mounts--mounts worked good for me never broke em never broke axles-now i swapped a b18c myself using them same mounts no probs and hood closes perfect--
Old Dec 30, 2001 | 07:42 PM
Jared's Avatar
It will not break if it's welded correctly. I've done countless reweld EF swaps, including my own(3 years and still holding all I throw at it) and never had problems. And you aren't welding to sheet metal, you're welding to the frame rail.
d1nki
Dec 29, 2013 03:20 PM
1QuikSOHCZC
11
Jun 17, 2010 03:34 PM
tallkan
May 6, 2007 11:28 AM
bbrian
May 29, 2005 08:39 PM
Jonathan_ED3
14
Mar 16, 2002 04:55 PM
