Project Punisher - UPDATE! Bottom-end's finished
Old Nov 12, 2004 | 05:40 PM
B16A1-EF9's Avatar
Default Project Punisher - UPDATE! Bottom-end's finished
The bottom-end setup is:
95 B18C1 GSR
Modified oiling system
Darton M.I.D sleeves
Wiseco Flat-top coated pistons - 9.7:1 compression
Carrillo H-beam connecting rods
Lightened, knifedged and balanced crankshaft
Cyrogenically treated pistons, rods and crank
New bearings and seals
Old Nov 12, 2004 | 05:43 PM
ATS*Mark's Avatar
OG triple OG
Default Re: Project Punisher - UPDATE! Bottom-end's finished (B16A1-EF9)
sick!!
Old Nov 12, 2004 | 05:45 PM
Phil Koury's Avatar
Default Re: Project Punisher - UPDATE! Bottom-end's finished (OnePointSicks)
Looks good, how much did you put into the bottom end? What did you do for the oiling system?
Old Nov 12, 2004 | 06:19 PM
b00sted93Hatch's Avatar
Look really good. Post some number when you get it running. What kind of turbo are you going to run?
Old Nov 12, 2004 | 07:25 PM
malaya's Avatar
How much did the bottom end set up run you? if you don't mind me asking. looks good.
Old Nov 12, 2004 | 07:55 PM
Muckman's Avatar
Moderator in Chief
How did you get that '95 GSR block so clean? My '00 block was hot tanked many times and doesnt look anything like that!
Old Nov 12, 2004 | 08:20 PM
done's Avatar
Default Re: Project Punisher - UPDATE! Bottom-end's finished (Muckman)
im jealous, i wish my block would have went as planed.
Old Nov 12, 2004 | 08:27 PM
Maveric's Avatar
Default Re: Project Punisher - UPDATE! Bottom-end's finished (Jordo)
sweet....what turbo you gonna boost with?
Old Nov 12, 2004 | 08:31 PM
plusONE jboy's Avatar
damn, thats like a work of art.
Old Nov 12, 2004 | 09:38 PM
.dave's Avatar
i HAS questions ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">How did you get that '95 GSR block so clean? My '00 block was hot tanked many times and doesnt look anything like that!</TD></TR></TABLE>
You have to hot tank it in Canadian water.
Looks sick. What kind of car is this going in?
Old Nov 12, 2004 | 09:50 PM
wHOAlly's Avatar
media/bead blast it
Old Nov 12, 2004 | 10:56 PM
Maxime's Avatar
Default Re: Project Punisher - UPDATE! Bottom-end's finished (pkoury)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pkoury &raquo;</TD></TR><TR><TD CLASS="quote">Looks good, how much did you put into the bottom end? What did you do for the oiling system?</TD></TR></TABLE>
More then you can afford pal!!!!
Old Nov 12, 2004 | 10:58 PM
top fuel's Avatar
wow
Old Nov 13, 2004 | 10:28 AM
int3gra's Avatar
Default Re: (top fuel)
Amazing setup, now bring it in for tuning
Old Nov 13, 2004 | 10:49 AM
Griffin@Camtech's Avatar
Default Re: (int3gra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by int3gra &raquo;</TD></TR><TR><TD CLASS="quote">Amazing setup, now bring it in for tuning </TD></TR></TABLE>
would you use hondata or uberdate to tune that short block??
nice setup
Old Nov 13, 2004 | 03:39 PM
B16A1-EF9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Looks good, how much did you put into the bottom end? What did you do for the oiling system?</TD></TR></TABLE>
Well Cesar at Mississauga Engines modifies the stock pumps for more pressure or something and also makes them stronger since they like to break, he also cleans up all the passages in the block.
I have no idea how much it's all costing me yet since I didn't get billed yet.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Look really good. Post some number when you get it running. What kind of turbo are you going to run?</TD></TR></TABLE>
Thanks. I won't have any numbers for awhile since I have to finish the car first. The car is getting repainted and restored still. The turbo I'm running is a T04R from Cheapturbo.Com, it's a .82 T3 exhaust, with a .70 67-1 intake side.
Thats right, bead blasted....bringd out the aluminum. I'm still going to paint the motor gunmetal though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">would you use hondata or uberdate to tune that short block??
nice setup </TD></TR></TABLE>
NO WAY! I'm going to use a full standalone for this. It's alot more flexible...the processing speed is alot higher. And there is more features. I wouldnt use piggybacks or chips to run this. I just spent over 10,000 on the motor why would I put in $500 management???
The block is done but I still have alot of hours to invest in the cylinder head.
Old Nov 13, 2004 | 04:53 PM
The Destroyer's Avatar
How much where the mid-sleeves?
Old Nov 13, 2004 | 05:06 PM
mrbsponge's Avatar
super nice
Old Nov 13, 2004 | 06:08 PM
WREKONIZE V8 KLR's Avatar
awesome job
the mid sleeves are around $550, or $300 if you are me
Old Nov 13, 2004 | 06:43 PM
ghettochild's Avatar
Default Re: Project Punisher - UPDATE! Bottom-end's finished (WREKONIZE V8 KLR)
that bitch looks mean bro
Old Nov 13, 2004 | 08:32 PM
RenoRacing's Avatar
Default Re: Project Punisher - UPDATE! Bottom-end's finished (ghettochild)
Lovin' the high compression turbo block! well done!!!
Old Nov 13, 2004 | 09:00 PM
Boostage's Avatar
Default Re: Project Punisher - UPDATE! Bottom-end's finished (RenoRacing)
what do u mean modifed oil system?
Old Nov 13, 2004 | 09:18 PM
JDMs1eeper's Avatar
Nice bottomend
I believe its called "shimming the oil pump" right? I had it done a few years back to a H23 i built. Ups the Oil pressure
Old Nov 13, 2004 | 11:53 PM
ISSUES-EG's Avatar
Default Re: Project Punisher - UPDATE! Bottom-end's finished (JDM S1eeper)
Old Nov 14, 2004 | 06:44 AM
turbo96wr's Avatar
did you crio the piston's after the coating or before i think if you coat after crio the heat would effect the crio, correct me if i'm wrong.
