F.S. GSR shortblock!
Still up for sale guy/Gals!
Alright guys here is the Shortblock I have for sale. It does need to be repaired though. Where the BIG motor mount bolts to the bracket. Well the three bracket holes need to be filled and retapped. I am saling it for $500.00! Only has 40K miles on it. And it is a USDM motor.
Modified by Blitzed at 8:10 PM 11/20/2004
It happened due to a guy not tightening up the Mount. And was taken apart cause it was going to be a build up!
how could that even get filled? If it was assembled and those holes werent there then it would be a good deal. I dont think welding would even work, its such a big hole. Probably would have to drill it, and press in a plug, and then drill/thread that plug. That would probably work, weld the plug on the edges, but aluminum is expensive to work on. so i dont know.....
We have had a customers car get fixed before like this. They are mounting holes man.....Do you not know what you are looking at? It just gets tig welded, filled and retapped man.
