Clutch fluid leaking **HELP**
Old Nov 12, 2004 | 02:38 PM
AlphaQup's Avatar
Default Clutch fluid leaking **HELP**
The strangest thing happend today. I always take my autolock off without looking at it, but today I looked at it. And to my amaze, there was clutch fluid on it.
After inspecting where the leak was coming from, I found out its only been leaking for a few days max because the carpet only has a small wet-spot on it.
Has anybody ever encountered this problem? Let me know what you had to replace in order to stop the leak. I'm thinking the autolock played a major role in f*cking my **** up.
Your help is much obliged.
Old Nov 12, 2004 | 03:47 PM
smart monkey's Avatar
Default Re: Clutch fluid leaking **HELP** (AlphaQup)
clutch master is going out
Old Nov 12, 2004 | 04:33 PM
86si's Avatar
Default Re: Clutch fluid leaking **HELP** (smart monkey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smart monkey &raquo;</TD></TR><TR><TD CLASS="quote">clutch master is going out</TD></TR></TABLE>
Old Nov 13, 2004 | 12:10 AM
AlphaQup's Avatar
Default Re: Clutch fluid leaking **HELP** (86si)
OK so I gotta replace the CMC. I know there's gotta be some of you guys out there that use the autolock on your clutch pedal. Have you encountered this same ****? I really dont wanna lock my brake pedal, since it's basically pointless.
Flux
Jan 17, 2012 03:32 PM
KloC 95 EG
Mar 13, 2006 09:18 PM
jonnytuner
Mar 4, 2006 04:06 PM
crdcz03
May 5, 2005 06:43 PM
type_sml
Aug 23, 2002 12:53 PM
