ZC transmission
Old Nov 12, 2004 | 02:07 PM
lmiguelvv's Avatar
Default ZC transmission
will a ZC tranny fit a d16y7 block?
BauleyCivic's Avatar
Risky Business
Default Re: ZC transmission (lmiguelvv)
Yes
Old Nov 12, 2004 | 02:29 PM
lmiguelvv's Avatar
does a DOHC tranny fit a d16y7 engine
Old Nov 12, 2004 | 05:28 PM
lucasbkellner's Avatar
Default Re: (lmiguelvv)
ZC is DOHC but it is still a D series engine.
I can't tell you for sure if it will bolt right up though. If there is any difference it will be in the diameter of the input shaft. But I could be completely wrong about that.
Old Nov 12, 2004 | 05:29 PM
jerbear!'s Avatar
It will bolt right up.
Old Nov 12, 2004 | 05:30 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lmiguelvv &raquo;</TD></TR><TR><TD CLASS="quote">does a DOHC tranny fit a d16y7 engine</TD></TR></TABLE>
just to be clear, if you are asking if any DOHC tranny will fit on a d16y7 the answer is no.
No B series transmission will fit to a D series engine.
All D series transmissions will fit to a D series engine. Except MAYBE the ZC, somebody else needs to give you the definite answer on that.
Old Nov 17, 2004 | 12:20 AM
del_orson's Avatar
It should bolt up, but you will need a fly wheel and clutch to go with the tranny. Also you may need the axles to go with it and i dont think that your engine block is drilled and tapped for the intermediate shaft.
Old Nov 17, 2004 | 12:57 AM
BukakkEK9's Avatar
It will bolt up just fine, and you dont have to use the intermediate shaft. You would need to check to make sure the clutch disk will match up tho...honda went all sketchy with the d-series tranny's back in the day some had 20 spline imput shafts some others had 21..im assumeing this is going into a 91 or earlier car that has a Y7 block right?
Old Nov 17, 2004 | 10:19 AM
jerbear!'s Avatar
question, gear ratios of a zc are comparable to what d series tranny
Old Nov 17, 2004 | 10:25 AM
SOHC4life 96's Avatar
Default Re: (jerbear!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jerbear! &raquo;</TD></TR><TR><TD CLASS="quote">question, gear ratios of a zc are comparable to what d series tranny</TD></TR></TABLE>
y8/z6?
Old Nov 22, 2004 | 08:58 PM
del_orson's Avatar
I just swiched from a zc to a 90 civic si and I really didnt notice much of a difference.
Old Nov 22, 2004 | 09:45 PM
jerbear!'s Avatar
cuz there is none!
circapunk
Jun 4, 2008 07:15 PM
Run Away
Dec 19, 2006 05:29 PM
civicprojectPR
13
Feb 11, 2005 08:25 AM
SOHC_Ek9
Feb 26, 2004 07:06 AM
