power window not on track?
last nite i went to roll down my driver side window and it fell about half way down and then made a cranking sound like it was off track. a friend of mine with a civic said he had the same problem and that its a bent window regulator causing it. the thing is i found two bolts rolling around in the bottom of my door panel beforehand leading me to believe something may have been loose. any ideas as to what may be wrong? thanks in advance
ryan
ryan
those small 10mm's hold the window regulator on...
Hondas are known for bad window regulators... wouldnt supprise me if yours was going out.
Worst case get a new window regulator assembly, and install it.
TwoKSiR
Nov 4, 2007 02:33 PM
00ekcoupe
13
Aug 27, 2005 10:52 AM
