hondata
Old Nov 12, 2004 | 12:41 PM
Import_Dumbass's Avatar
Default hondata
yeah yeah yeah, i know im going to get flamed and yelled at to use the search, but i did and scaned the first few pages and didnt see too much of help, saw a bit of stuff for sale and some random other things, but that was about it.
so whatexactly is a hondata tuner for? it seems alot of people who are boosted use it? what does it do? and if you know, how does it operate?
Old Nov 12, 2004 | 12:52 PM
BauleyCivic's Avatar
Risky Business
Default Re: hondata (Import_Dumbass)
It's a piggyback engine management system that allows full manipulation of fuel and ignition tables, vtec engagement, etc
Check out http://www.hondata.com
Old Nov 12, 2004 | 12:53 PM
klungemonger's Avatar
Hondata is a tunable engine management system that can be installed into OBD1 ecus, it allows fuel & ignition maps to be altered, VTEC points changed, knock sensors to be disabled, and with the extra $$$ options it allows Honda ecus to read boost (stock ecu's can only read vacuum from the MAP sensor)
Read up at http://www.hondata.com
Old Nov 12, 2004 | 01:02 PM
Default Re: hondata (klungemonger)
thanks you guys. helped alot :-D
Old Nov 12, 2004 | 02:13 PM
Mr.E.G.'s Avatar
hondata should not be thought of as a piggy back computer.
a piggy back interupts signals to the computer and sends a simulated signal to trick the computer into doing something.
hondata is an interface that allows you to tune the factory computer. it more or less converts the factory computer into a standalone. not trying to sound like a dick, but it is not a piggyback
Old Nov 12, 2004 | 02:14 PM
Risky Business
Default Re: (Mr.E.G.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.E.G. &raquo;</TD></TR><TR><TD CLASS="quote">
hondata is an interface that allows you to tune the factory computer. it more or less converts the factory computer into a standalone. not trying to sound like a dick, but it is not a piggyback</TD></TR></TABLE>
Its still a reburned chip that goes into the ECU. It is not standalone.
AEM EMS, Motec are standalone.
Old Nov 12, 2004 | 02:30 PM
Twiet's Avatar
and a blue box
but I think he meant it more in a way as: Hondata should not be seen as for instance a VAFC.. which basicly is a toy compared to Hondata... so calling Hondata a piggyback isn't doing this system a whole lot of justice.
Old Nov 13, 2004 | 06:42 AM
Mr.E.G.'s Avatar
it obviously is not the same thing as an EMS or whatever but it should not by any means be considered a piggy back
Old Nov 14, 2004 | 12:43 PM
racingfan's Avatar
can you hook up your laptop to your hondata so you can read the hondata logger.
Old Nov 14, 2004 | 01:55 PM
ce's Avatar
ce
yup
mtber
Engine Management and Tuning
24
Apr 16, 2014 08:09 PM
teler86
Mar 2, 2006 04:52 PM
spoonhatchblack
Oct 4, 2004 12:18 PM
mugenkilla899
Mar 29, 2004 04:08 PM
Integra187
Sep 6, 2001 06:27 PM
