is it a must to use a fuel pressure regulator when using a ctr pistons in a b16a2
Old Nov 12, 2004 | 12:20 PM
vtibrazil's Avatar
Default is it a must to use a fuel pressure regulator when using a ctr pistons in a b16a2
we have recently put together a b16a2 with buddy club 3+ cams and ctr pistons we put the timing back to adjust to the pistons but it is still giving pre egnition...would that be because of the fuel being used?? (octane) or lack of fuel pressure since we haven't done anything to the fuel system???
Old Nov 12, 2004 | 01:43 PM
kaptr1d's Avatar
Default Re: is it a must to use a fuel pressure regulator when using a ctr pistons in a b16a2 (vtibrazil)
stock fuel system and NO tuning at all?
eek, id say ur lucky to be running at all.
Old Nov 12, 2004 | 03:23 PM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: is it a must to use a fuel pressure regulator when using a ctr pistons in a b16a2 (kaptr1d)
could be either, octone or lack of fuel , you need to get some sort of fuel help i.e fuel regulator/guage, or apexi VAFC
Old Nov 12, 2004 | 03:43 PM
vtibrazil's Avatar
Default Re: is it a must to use a fuel pressure regulator when using a ctr pistons in a b16a2 (HOOKUPS)
just pumping up the fuel pressure to maybe 3 bars and a 1/2 and chip tunning would be enought???
Igaly
Honda Civic (2001 - 2005)
Apr 16, 2009 03:17 PM
toooslow
May 15, 2003 12:21 PM
McFly
Mar 5, 2003 08:09 PM
BeEfiEBuNz
Nov 17, 2002 05:18 AM
