Need some help from tuners
Old Nov 12, 2004 | 06:15 AM
prada_2o0o's Avatar
Default Is there more potential??? Need some help from tuners
Hopefully that worked, its on imagestation, Anyways, I need some input on my engine, right now it has just been street tuned , no adjustments to the cams, and a fairly conservative fuel map. I was wondering for those of you who have tuned a quite a few engines what kind of potential you see from here.
Right now the biggest bottleneck i think is my b16 throttle body, here is my setup
LS/vtec
ls block, shotpeened ls rods, p30 pistons0.25os, balanced and blueprinted bottom end, with ctr crank pulley, lightened flywheel, clutch balanced as well. all the arp head/rod bolts.
itr head, ctr cams(no diff really, head is from 2001 itr) ported and polished, itr intake manifold, 5 angle grind on the valves, supertech .5 over valves, gasket matched(exhaust and intake side), T1r header,T1R test pipe, 2.5" exhaust and my small b16 throttle body. 2001 itr tranny.
I guess my main question for you guys with experience is if i through a spoon tapered throttle body(or another one if suggested) on there and get some tuning on the dyno, i need to move the vtec engagement point,(kicks fairlyhard) and play with the cams. Can i hit 190-195whp, I only have 91 octane here to work with.
Thanks in advance for your help
Modified by prada_2o0o at 7:33 PM 11/12/2004
Modified by prada_2o0o at 10:30 PM 11/12/2004
Modified by prada_2o0o at 5:42 AM 11/13/2004
Modified by prada_2o0o at 5:43 AM 11/13/2004
Old Nov 12, 2004 | 06:37 AM
mtber's Avatar
Can't see your graph...
I doubt you will hit 190s on that setup.
Maybe high 180s if your lucky.
Old Nov 12, 2004 | 07:21 AM
prada_2o0o's Avatar
Default Re: (mtber)
the numbers were 181whp and 135.6wtq... 190 is only 9hp away with.. i was hoping it is reachable seeing as my vtec engagement is off, im sure i can get some out of the cams(they havent been touched) sitting at 0... and i was hoping with all the headwork, the new tb should give me a bit, the b16 tb is soo small
prada_2o0o's Avatar
Default Re: (prada_2o0o)
Is there anywhere else i can host this graph? you can see a huge jump at my vtec engagement point on the tq side,
Old Nov 12, 2004 | 07:35 AM
99-DC2's Avatar
190+whp is definitely doable with your setup... a 64mm TB will be enough to reach your horsepower goals...
Old Nov 12, 2004 | 07:46 AM
prada_2o0o's Avatar
Default Re: (DC2-99)
would you recommend a straight through tb, or the tapered spoon 70mm-64mm? i thought it would be a huge bottleneck, its just been getting cold so i havent had time to do much work on the engine. I am happy with the torque numbers tho,
Old Nov 12, 2004 | 01:30 PM
prada_2o0o's Avatar
just got a good price on a spoon throttle body, going to go order it up this weekend
Old Nov 12, 2004 | 03:09 PM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
rpm t-bodies billet allum. 285.95 in stock 62mm up to 72mm
Old Nov 12, 2004 | 03:31 PM
prada_2o0o's Avatar
Default Re: (HOOKUPS)
anyone else have any ideas what this setup may reach with some tuning of cam gears and the spoon tb?? Forgot to mention this is all tuned with Hondata S200
Old Nov 12, 2004 | 04:40 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
i believe on a better tune you can hit 190....i laid downthe same #'s with a stock usdm GSR block with a P72.....
good luck
Old Nov 12, 2004 | 04:51 PM
99-DC2's Avatar
personally I like the tapered TB's but either one will produce the results you want...
Old Nov 12, 2004 | 07:01 PM
prada_2o0o's Avatar
Default Re: (SnoFlake EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SnoFlake EG &raquo;</TD></TR><TR><TD CLASS="quote">i believe on a better tune you can hit 190....i laid downthe same #'s with a stock usdm GSR block with a P72.....
good luck </TD></TR></TABLE>
what kind of tq were you laying down?
Old Nov 12, 2004 | 07:27 PM
Race Egr's Avatar
Get the dyno graph posted so we can see whats goin on. Changing the vtec point is not gonna give you more power. It may feel like it because if you set it lower then you get a bigger jump in power ,but not anymore power
Old Nov 12, 2004 | 07:44 PM
10000rpm's Avatar
you will hit over 190@wheels cus your fuel and timing is not maxed out yet and your throttle body is another 2-4 @ the wheels
Old Nov 12, 2004 | 08:44 PM
prada_2o0o's Avatar
Default Re: (10000rpm)
hopefully that works. EDIT pic should be working
Old Nov 13, 2004 | 08:48 AM
Eddiebx's Avatar
u have any AFR plots?
Old Nov 13, 2004 | 05:12 PM
prada_2o0o's Avatar
Default Re: (Eddiebx)
i will have to get them ..ill try and get them posted asap
Old Nov 14, 2004 | 12:24 PM
PupaScoopa's Avatar
Default Re: (NAPIER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAPIER &raquo;</TD></TR><TR><TD CLASS="quote">Get the dyno graph posted so we can see whats goin on. Changing the vtec point is not gonna give you more power. It may feel like it because if you set it lower then you get a bigger jump in power ,but not anymore power</TD></TR></TABLE>
It can give more power. If you tune it right so there is more "area under the curve" instead of a sharp peak, you'll have more overall power. Calculus mang...
Old Nov 14, 2004 | 01:23 PM
riceball777's Avatar
Default Re: Is there more potential??? Need some help from tuners (prada_2o0o)
you have to hit at least 200 hp on a dyno pack to have 190whp due to the fact the wheels are taken off when means its not wheel hp
Old Nov 14, 2004 | 09:12 PM
Eddiebx's Avatar
Default Re: Is there more potential??? Need some help from tuners (riceball777)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceball777 &raquo;</TD></TR><TR><TD CLASS="quote">you have to hit at least 200 hp on a dyno pack to have 190whp due to the fact the wheels are taken off when means its not wheel hp </TD></TR></TABLE>
its all about the correction factor used that determines how far off you are from a dynojet. not having wheels doesn't mean its not "wheel horsepower"
for example one dynapack that I tune on, dynoed within 2hp of two other local dynojets, on the same day. the shop tested that one day just to shut ppl up.
Old Nov 15, 2004 | 06:32 AM
prada_2o0o's Avatar
Default Re: Is there more potential??? Need some help from tuners (Eddiebx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx &raquo;</TD></TR><TR><TD CLASS="quote">
for example one dynapack that I tune on, dynoed within 2hp of two other local dynojets, on the same day. the shop tested that one day just to shut ppl up.</TD></TR></TABLE>
exactly, i have had the car dyno'd before and put down around 180.2 i believe with the wheels on. I have the other sheet somewhere just used this one because i had it on hand .
UPDATE I ordered my spoon throttle body and it should be in , in 2 weeks, i will update you guys when it comes in, and i am tuned. ALSO i will be adding pictures of the setup tonight. Thanks
Old Nov 17, 2004 | 09:18 AM
prada_2o0o's Avatar
seeing as my head is port + polished and portmatched to my Intake manifold should i be port matching the itr IM to the spoon tb?? and get the IM worked on at the same time?? do alot of you port your Intake manifolds? would it be worth it with this setup.. i see alot of turbo cars port there im's with nice gains
em1_fox
Aug 19, 2009 10:30 AM
ekBlackHatch
82
Jan 28, 2009 09:34 PM
RACING INTEGRATION
10
Dec 10, 2007 12:56 AM
Yak BallZ
Jun 27, 2005 12:29 AM
wdyno
Oct 16, 2001 08:44 AM
