si rear disc conversion?
Search please next time. There are about 1,587,385,635 posts on this topic.
There are a few different ways to do this.
1. Get entire rear trailing arm assembly along with the e-brake cables. Preferably also the m/c and prop valve.
2. You can also just swap out the the entire spindle with the drum disc on it since the rear trailing arms are the same.
-Shane
-Shane
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nighttrain33 »</TD></TR><TR><TD CLASS="quote">Search please next time. There are about 1,587,385,635 posts on this topic.
-Shane</TD></TR></TABLE>
Correct. And also be prepared to spend about 200 bucks. Or more. If you dnt need the upgrade in brakeing then dont waste your money. Also you can use 92-00 civic rear disc. And also 94 and up integra.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slow98sedan »</TD></TR><TR><TD CLASS="quote">Even if he just swaps out the spindle ***,shouldnt he still also replace the M/C and Prop Valve?
Just curious on this one..
..adam..</TD></TR></TABLE>
Master cylinder is not a necessity but VERY VERY helpful. The proportioning valve is a must though.
Are YOU calling me an ***??? "We ain't on your block anymore, you better watch who you talk to like that!" Anyhow, yes it would still be good to get the mc and prop valve, but I didn't get either when I did my swap and it is fine. I know that when I upgrade my brakes more that I will for sure have to get a bigger mc anyway, so might as well do it now.
-Shane
-Shane
WOO I didnt have to answer this.
"***" => Assembly Mr quote from the fast and the furious
^and your quote is from The Rock - Cage to Connery.
Will you paypal me the $100million?
I live in the same town, and you should be able to find me. It isn't that hard. If you can do so then I will give it to you.
. By the way, your post had nothing to do with this thread
. And it took you long enough to figure out The Rock qoute anyway. Didn't I tell you there was a time limit for that one. Damn, must not have. Besides, that was kind of another quote and that's why I put it in there. So ha
-Shane
-Shane
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA »</TD></TR><TR><TD CLASS="quote">
Master cylinder is not a necessity but VERY VERY helpful. The proportioning valve is a must though.</TD></TR></TABLE>
It is not a necessity. I did my rear disc and still have my stock ex prop valve. 4 wheel lock ups are fun. I know you SHOULD get one but you dnt NEED it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 »</TD></TR><TR><TD CLASS="quote">
It is not a necessity. I did my rear disc and still have my stock ex prop valve. 4 wheel lock ups are fun. I know you SHOULD get one but you dnt NEED it.</TD></TR></TABLE>
I could be wrong but i heard that if you dont get the valve that the fluid isnt distributed to the rear brakes as well and making the rear discs almost pointless. I could be wrong though...anyone else?
Haing rear discs in the rear does take moving more fluid that having the drums, so it is good to have the 4-wheel prop. valve, but braking is still better (somewhat) even without it.
-Shane
-Shane
specialized108
21
Nov 7, 2008 04:44 PM
eg:R
Jan 29, 2006 06:50 PM
