Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Who makes a 24+mm Rear Sway Bar for Integras?
Old Nov 12, 2004 | 05:56 AM
jwaked's Avatar
Default Who makes a 24+mm Rear Sway Bar for Integras?
I need a 24mm or larger rear sway bar but everyone makes 22mm for my 94 Integra. Any ideas? Thanks
Jay
Old Nov 12, 2004 | 06:03 AM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: Who makes a 24+mm Rear Sway Bar for Integras? (jwaked)
Mugen makes a 24mm and a 26mm bar. Goes for about $360 from King I think.
Old Nov 12, 2004 | 06:04 AM
JeffS's Avatar
Mugen - may be out of production
Saner - http://www.sanerperffab.com/ - can make whatever you want
Progress - don't they have a 24mm bar??? maybe it was only 22
Ground Control - sometimes they offer a 25mm bar.
Old Nov 12, 2004 | 06:17 AM
Xian's Avatar
Default Re: Who makes a 24+mm Rear Sway Bar for Integras? (JeffS)
Yep, Saner will make anything you want.
Progress makes a 23mm bar and possibly larger ones too?
edit: Progress makes a 22mm and 24mm bar... not a 23mm bar
Modified by Xian at 10:44 AM 11/12/2004
Old Nov 12, 2004 | 06:23 AM
jwaked's Avatar
I just looked and Mugen makes a 24mm for $390. The 26mm is for the front. Progress is 22mm. Saner does not show the bar for integras. I know they can probaly make it for me but I am out of time. I need one ready to ship. Thanks guys.
Jay
Old Nov 12, 2004 | 06:29 AM
JeffS's Avatar
Default Re: (jwaked)
I don't think you'll find anything ready to ship. Like I said, I think Mugen has been discontinued. Maybe you could find one used.
Old Nov 12, 2004 | 06:42 AM
jwaked's Avatar
The Cusco bar shows to be 25mm.
Old Nov 12, 2004 | 06:44 AM
Xian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwaked &raquo;</TD></TR><TR><TD CLASS="quote">I just looked and Mugen makes a 24mm for $390. The 26mm is for the front. Progress is 22mm. Saner does not show the bar for integras. I know they can probaly make it for me but I am out of time. I need one ready to ship. Thanks guys.
Jay</TD></TR></TABLE>
Progress makes a 24mm bar also... http://www.progressauto.com/Ci...s.htm
Old Nov 12, 2004 | 06:49 AM
jwaked's Avatar
Thats for Civics.
Old Nov 12, 2004 | 06:52 AM
Xian's Avatar
Essentially the same chassis... should be able to use the Civic stuff.
Old Nov 12, 2004 | 07:02 AM
JeffS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwaked &raquo;</TD></TR><TR><TD CLASS="quote">Thats for Civics.</TD></TR></TABLE>
As mentioned above, any rear bar made for a civic or integra is interchangeable.
The only exception to this is that a bar made for a regular civic or integra may not fit on an ITR. RJ and I learned this the hard way after he bought my Ground Control bar made for civics/integras and tried to put it on the ITR.
- not that this effects you, just adding it as useful information for the archives.
Old Nov 12, 2004 | 07:06 AM
typer_801's Avatar
Default Re: (JeffS)
Whiteline makes at 24mm adjustable bar. Corresponds to 22 in soft and 26mm in stiff setting. Under $200. I've got it installed on my R. Works great! Includes poly bushings and endlinks. Part #BHR72Z It was in stock and took two days to arrive when I ordered it this past summer.
Old Nov 12, 2004 | 07:14 AM
JeffS's Avatar
Default Re: (typer_801)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typer_801 &raquo;</TD></TR><TR><TD CLASS="quote">Corresponds to 22 in soft and 26mm in stiff setting.</TD></TR></TABLE>
I think this is a misadvertisement. A 4mm change in bar size is HUGE. Comptech, for example, claims about a 5% change between each of their three settings. This seems like a much more realistic number.
Old Nov 12, 2004 | 07:30 AM
jwaked's Avatar
Where can I find Whiteline´s phone number or website? Thanks
Jay
Old Nov 12, 2004 | 07:32 AM
JeffS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwaked &raquo;</TD></TR><TR><TD CLASS="quote">Where can I find Whiteline´s phone number or website? Thanks
http://www.google.com/search?s...eline
First link... aren't search engines great
Old Nov 12, 2004 | 07:52 AM
mstewar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typer_801 &raquo;</TD></TR><TR><TD CLASS="quote">Whiteline makes at 24mm adjustable bar. Corresponds to 22 in soft and 26mm in stiff setting. Under $200. I've got it installed on my R. Works great! Includes poly bushings and endlinks. Part #BHR72Z It was in stock and took two days to arrive when I ordered it this past summer.
I guess shipping to the U.S is lower than their example of Singapore.. using their example it was like $212 shipped via "Post"..
For my ITR, whiteline and saner are my top two choices right now.. I didn't know progress made a 24mm adjustable though, so that might be another good option.. I need to talk to Saner next week and see what they'll charge me for one of their custom jobbers..
Old Nov 12, 2004 | 08:28 AM
sdchump's Avatar
Default Re: (Xian)
I have the Progress 24 mm adjustable rear sway bar on my integra. It will fit any civic or integra because it does not use the stock endlink points on the LCA. It actually comes with all these steel pieces and hiem(sp?) bolts to make an endlink which attaches where the bottom of the shock meets the control arm.
In terms of stiffness, I can't really tell you how it compares to a 22mm bar because I went from a stock GSR sway bar to the Progress one. One thing to keep in mind is on the Progress setup, the endlinks are moved further out from the center of the chassis, which i think causes the bar to be a bit less stiff because of the longer moment arm, thus reducing torsional rigidity. Also, the adjustability is a feature that I am a bit sketch about. At the end of the bar is just a big slot, so u just tighten the bolt down wherever u want. The bolt actually lost grip and the sway bar slipped last time I was autox-ing so my last run was with virtually no sway bar.
In hindsight, I wouldn't recommend getting the Progress sway bar. Just get a bar that attaches to the stock endlink points. It will probably be less of a hassle in the long run and just as stiff.
Old Nov 12, 2004 | 08:36 AM
jwaked's Avatar
Anyone had any experience with Cusco?
Jay
Old Nov 12, 2004 | 08:44 AM
typer_801's Avatar
Default Re: (mstewar)
Global Parts Source in Holland, Michigan is the North American distributor of Whiteline products. It shouldn't cost too much to get something shipped if they have it in their warehouse.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mstewar &raquo;</TD></TR><TR><TD CLASS="quote">
I guess shipping to the U.S is lower than their example of Singapore.. using their example it was like $212 shipped via "Post"..</TD></TR></TABLE>
Old Nov 12, 2004 | 08:59 AM
JeffS's Avatar
Default Re: (sdchump)
Actually, attaching further out on the lca would make it more effective. I agree with you on the slotted mount at the bar though... that seems like a problem waiting to happen. I'd probably have to fabricate something - probably via welding wire - to keep it from slipping. I wouldn't adjust it anwyay though, just set it at the stiffest setting and go.
Old Nov 12, 2004 | 09:01 AM
jwaked's Avatar
Do you have Golbal Parts´ number?
Modified by jwaked at 7:07 PM 11/12/2004
Old Nov 12, 2004 | 09:04 AM
JeffS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwaked &raquo;</TD></TR><TR><TD CLASS="quote">Do you have Golbal Parts´ number?</TD></TR></TABLE>
http://www.google.com/search?h...ce%22
5th link
You should seriously try this search engine thing. Some say it's just a fad, but it may eventually catch on.
Old Nov 12, 2004 | 09:06 AM
Xian's Avatar
Default Re: (JeffS)
nah, search engine's will never catch on... too hard to use
also, if the 5th link down in too much work, here's a link where it's the 3rd one down. http://www.google.com/search?h...ce%22
Christian, who sometimes wonders if people have never used google...
Old Nov 12, 2004 | 09:23 AM
Mr Hammond's Avatar
a/k/a Jomo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwaked &raquo;</TD></TR><TR><TD CLASS="quote">I just looked and Mugen makes a 24mm for $390. The 26mm is for the front.</TD></TR></TABLE>
Hmmm...Maybe then don't make it anymore.
I know Mugen used to make one. I'm 99% sure Ed (Zygspeed) use to run it, among others as well.
Old Nov 12, 2004 | 10:08 AM
Hracer's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwaked &raquo;</TD></TR><TR><TD CLASS="quote">I need a 24mm or larger rear sway bar but everyone makes 22mm for my 94 Integra. Any ideas? Thanks
If the rear suspension geometry of the '90-93 Integra is the same as the '94+ (except for ITR), then consider the 25 mm adjustable rear sway bar that Walt from Delta Group Motorsports makes. It uses the stock mounting points of the LCA. Pic below.
