BRAKE QUESTION
Old Nov 11, 2004 | 10:09 PM
joedubovik's Avatar
Default BRAKE QUESTION
ok, ive got an ek civic coupe. welll. my pads went out the other night. and started scrapin so i picked up some new ones, im changin them out. and long story short the piston came out and caused hell (we will not explain how it got out ) well, i finally get it all back together and start it up and im able to push my pedal to the floor with no problem, fluid is fine..
do i need to bleed my clutch, or is my caliper crapped out.
just want to ssee what you guys think about this.
Old Nov 11, 2004 | 10:13 PM
2000EM1's Avatar
Default Re: BRAKE QUESTION (joedubovik)
have you tried pumping your brakes? When I changed my pads last month I started the car up and the pedal went to the floor as expected, all i had to do was pump the pedal and the pressure came back within a few seconds.
How did you put the caliper back on? did you press the piston back in with the old pad and a C clamp or did you just throw the C clamp on the piston itself? sometimes they'll get stuck cockeyed and then you'll have to end up buying a whole new caliper.
Old Nov 11, 2004 | 10:20 PM
joedubovik's Avatar
Default Re: BRAKE QUESTION (revolution8k)
yeah i pumped the brakes. i tried driving my car down the street... near death. the caliper is in there smoothly, im gonna bleed my brakes first thing in the am and see what that does for me.
thanks man
Old Nov 11, 2004 | 10:21 PM
Evs-One's Avatar
Solbros Owns Me
did you get the dust boot over the piston properly? This can be quite an annoying task
Old Nov 12, 2004 | 07:34 AM
joedubovik's Avatar
Default Re: BRAKE QUESTION (Emerika)
EXTREMELY annoying. yes i did tho, with the help of a small straight slot.
Old Nov 12, 2004 | 08:32 AM
jbs's Avatar
jbs
Since the piston came out, you basically opened up the brake system. If you got it back together and fluid is not leaking, just blead the brakes and you'll be fine.
Old Nov 12, 2004 | 09:59 AM
joedubovik's Avatar
Default Re: (jbs)
done. i bled the brakes, they worked fine, no noticible leaks, well see what happens.
Old Nov 12, 2004 | 10:13 AM
ek9800's Avatar
Default Re: (joedubovik)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joedubovik &raquo;</TD></TR><TR><TD CLASS="quote">done. i bled the brakes, they worked fine, no noticible leaks, well see what happens.</TD></TR></TABLE>
if you can still push the brakes to the floor it might be your master cylinder going out
Old Nov 12, 2004 | 05:30 PM
joedubovik's Avatar
Default Re: (ek9800)
no, master cyl is fine, everything is good so far i was affraid my piston woulda been gushing fluid out all over, but brake fluid level is same, and ive driven like 20 miles, hopefully it stays like this.
can you tell the difference between stock ek calipers and lets say gsr by looking at them?
my car was modded before i bought
just incase i have to get a new caliper i need to know.
if you can tell me, and ill get some leet pics and you guys can help me out. k? sweet thanks
soon2bdropped
May 8, 2009 05:03 PM
. a d a m
Suspension & Brakes
Oct 22, 2008 10:21 AM
. a d a m
Oct 9, 2008 07:33 PM
uNF$@#!
Apr 28, 2003 12:17 PM
miataguy
Jan 26, 2003 11:25 AM
