what happens if the cam sprockets are off??? good or bad???
Old Nov 11, 2004 | 09:58 PM
frostee's Avatar
Default what happens if the cam sprockets are off??? good or bad???
Okay, today we reinstalled a timing belt on my h23vtec with a buddy of mine who has more experience with engines in general, but when he was putting the belt on, it looked as if the intake sprocket was fine but im thinking the exhaust sprocket was retarded by one teeth, but he said it was good. Engine starts up and and idles fine, but after you rev it, the rpms will drop real low to 400rpms for a split second then chokes a little too. Now im wondering what would happen if that cam sprocket was off?? is that what happens or does it do something else?? Any help or suggestions would be great, thanx.
Old Nov 12, 2004 | 01:21 AM
TimeRacer's Avatar
Default Re: what happens if the cam sprockets are off??? good or bad??? (frostee)
It's good! Actually if it's off by one tooth it won't do anything physically bad other than possibly screw up your power band. Why don't you fix it? If it's off by enough teeth though you can start bending stuff.
Old Nov 12, 2004 | 01:33 AM
WillsH22Accord's Avatar
id fix it to be safe.
Old Nov 12, 2004 | 03:04 AM
frostee's Avatar
I really want to fix it, but it's a real bitch to get to especially cause it's in a 91 hatch. but you're saying that just having the sprocket off by one teeth will not cause that problem right? If it's not the sprocket doing it then im not gonna play with that sprocket until i find what's causing the chocking.....
Old Nov 12, 2004 | 05:44 AM
00LudeLover's Avatar
Default Re: (frostee)
anything having to do with a car, espcially a honda, if it is considered "off" is not good.
i would defiantly fix it.
Old Nov 12, 2004 | 07:27 AM
kellyk75's Avatar
Default Re: (00LudeLover)
If you don't fix it, you will have long term problems. It is like having your timint way off.
Old Nov 13, 2004 | 11:17 PM
PrettyLude's Avatar
the car will run like crap with one tooth off
Old Nov 14, 2004 | 03:55 PM
Prolink's Avatar
First recheck the timing marks with the timing cover off before you take the whole thing off. Check vacuum lines, check connectors on iac and tps sensor.
journeyquest
Oct 3, 2011 04:07 PM
dick_213
Dec 2, 2004 04:33 PM
eastbay92cx
Jun 20, 2004 07:04 AM
AK94GSR
Jun 2, 2003 03:39 PM
PatrickGSR94
Apr 11, 2003 04:21 PM
