Need some insight with idle vibration problem
Old Dec 25, 2001 | 07:59 PM
CardDealer's Avatar
Banned
Default Need some insight with idle vibration problem
Modified by CardDealer at 3:30 PM 11/16/2006
Old Dec 25, 2001 | 10:10 PM
briq4's Avatar
Default Re: Need some insight with idle vibration problem (schlit)
OK of the three Honda Accords I have been in recently they ALL have the vibration issue at idle. My car has done it since I can remember and it's even worse when the A/C turns on... (Mine is a manual) but I do noitce that the vibration issue is a lot more pronounced on the automatic tranny Accords. You can see if it's the mounts but seems it's just an Accord thing. But should you go thru the engine mounts give a yell what the results are!
Old Dec 26, 2001 | 07:47 AM
Gennady's Avatar
New User
Do a search! I can remember at least 15 threads dealing with this issue. My suggest which somewhat aleviated my situation and slightly reduced the vibration is Bosch Platinum +4 plugs.
Old Dec 26, 2001 | 08:41 PM
CardDealer's Avatar
Banned
Default Re: Need some insight with idle vibration problem (Wont be beat)
Old Dec 27, 2001 | 09:13 AM
urbanlegend21's Avatar
New User
your idling is set to low, when you put the car in gear it drops the idling even more than when in park
either that or you drive band is not engaging properly
Old Dec 27, 2001 | 06:53 PM
1f9day's Avatar
Hey man I just replaced front dog bone on 90ex It solved my vibration in reverse It was real bad. Easy fix 70.00 hondautomotiveparts.com
Old Dec 27, 2001 | 06:57 PM
1f9day's Avatar
Default Re: Need some insight with idle vibration problem (1f9day)
EASY, check the top portion of dog bone u will see rubber inside is torn,mine was broke into pieces
Old Dec 29, 2001 | 10:05 AM
Avian's Avatar
New User
Browsing thru', friends '92 EX has the exact same problem. One question- What's the actual term for a dog-bone?
Old Dec 29, 2001 | 11:13 AM
Gennady's Avatar
New User
Default Re: Need some insight with idle vibration problem (Avian)
What is a dogbone?
Old Dec 29, 2001 | 12:59 PM
1f9day's Avatar
Torque strut is its legal name ,auto jargan dog bone , its looks like a metal dog bone . Located right behind left cooling fan 10 inches long with rubber bushings at both ends. When motor in gear its flexs to stabilize the twisting action of motor.Top rubber portion located to right of ehaust manifold and will crack and crumble .
Old Dec 29, 2001 | 03:10 PM
CardDealer's Avatar
Banned
Old Dec 29, 2001 | 06:23 PM
Avian's Avatar
New User
I'll give someone a cookie for a pic of it in an Accord.
Old Dec 30, 2001 | 01:43 PM
1f9day's Avatar
Hey Schlit go back to your pic #2 and #6 the mounts that hold the engine in place .....#15 just control torque action when put in gear. Unbolt the bone and it will fall out, better yet unbolt the top bolt of the bone. pull or rotate the bone toward front of car than better view of rubber inside. Engine motor control sys maybe your problem, but that is only the motor mount at you firewall..... but this is the easiest cheapest fix to try first. Comes complete with two round rubber heat shields in package. 2 day overnight ups .......really satisfied with this company........128.00 from local dealer...not
Old Dec 30, 2001 | 04:40 PM
CardDealer's Avatar
Banned
Modified by CardDealer at 3:29 PM 11/16/2006
youngkow
Jan 10, 2021 02:53 PM
turbokohm425
Engine Management and Tuning
Mar 26, 2012 01:59 AM
DaChoZn1
Jan 6, 2011 08:45 AM
integragsr97
May 28, 2004 03:21 PM
01IntegraSE
Nov 15, 2003 06:41 PM
