How To? Automatic to manual swap in 91 CRX???????
Old Nov 11, 2004 | 08:51 PM
95civicferio's Avatar
Default How To? Automatic to manual swap in 91 CRX???????
I have a 1991 CRX I want to put a b16 in it. I have the b16 part understood just need to know how the automatic to manual **** works. Are the mounts the same in an automatic as they are in a manual? I know I need the pedals, but how does the cable clutch work it's not like a 92-up civic which has a Master Cylinder hole in the fire wall. Has anybody done this before? If so tell me how. I did an automatic to manual b16 in my eg and it was not that complicated. I have the mind set to do it so now I just need to know how. Any body know?
Old Nov 11, 2004 | 08:54 PM
eumoria's Avatar
Default Re: How To? Automatic to manual swap in 91 CRX??????? (95civicferio)
your post is a little confusing... but this should help
http://hometown.aol.com/jrmupzaii/auto2man.html
Old Nov 11, 2004 | 09:02 PM
Default Re: How To? Automatic to manual swap in 91 CRX??????? (eumoria)
are the mounts the same?
Old Nov 11, 2004 | 11:12 PM
Putput's Avatar
For my 91 civic HB they were same.
You should go to the junk yard and pickup up the clutch pedal assembly, part of the rear wire harness and clutch relay, (this is to make the car not start unless the pedal is press). Its not that bad.
Old Nov 12, 2004 | 01:30 AM
92integra_gs's Avatar
good luck
Old Nov 12, 2004 | 08:21 PM
thanks
Mike_ef
Feb 24, 2013 08:50 AM
matos2revo
Aug 17, 2008 01:12 PM
UDRprojectHONDA
Apr 10, 2005 04:41 PM
95civicferio
Nov 11, 2004 08:49 PM
MICKSTER
Oct 2, 2002 09:08 AM
