94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams
Old Nov 11, 2004 | 08:46 PM
BlueIntegraBoy's Avatar
Default 94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams
I am tired of people asking where they can get diagrams to wire or repin an Integra cluster into their Civics. I took my time and searched the different wiring diagrams. I made my own diagrams for easy use. I made two diagrams for each 92-95 Civics and 96-00 Civics due to the different Integra clusters (94-97 and 98-01). I also included a diagram to wiring a 96-00 Civic cluster into a 92-95 Civic. Use at your own risk, I won't be responsible if your clusters go wacky.
NOTE: JDM Integra Type-R clusters will work with these diagrams. Make sure you know which spec cluster you have. 96 Spec will have a catalytic converter icon near the CEL and the 98 Spec do not. Use the 94-97 Integra diagram for 96 Spec and 98-01 Integra diagram for 98 Spec.
ANOTHER NOTE: To tell the difference between a 94-97 and 98-01 clusters is that the 94-97 clusters have grey gauge faces while the 98-01 clusters have black gauge faces. Also, 94-97 clusters have the seatbelt, door ajar, and SRS lights in the upper right light grouping, whle the 98-01 clusters have door ajar, ABS, and SRS in the upper right light grouping.
EXAMPLE: 96 Spec Integra Type-R Cluster
1994-2001 Integra Cluster into 1992-1995 Civic
1994-2001 Integra Cluster into 1996-2000 Civic
1996-2000 Civic Cluster Into 1992-1995 Civic
1992-1995 Civic Pin Designations
1996-2000 Civic Pin Designations
1994-2001 Integra Pin Designations
Rewiring SRS Plug (works for 96-00 Civics only, plug and play for 92-95 Civics)
Below is a picture of a Civic SRS plug. Notice that when the clip part is facing down, the yellow wire is of the left if the plug is facing away from you. The blue wire is one the right if the plug is facing away from you. You can use your Civic SRS plug with the Integra cluster. All you need to do is cut the yellow and blue wires and switch them (connect yellow to blue, and blue to yellow). So if this was an Integrs SRS plug, the yellow wire would be on the right, while the blue wire will be on the left; the plug again facing away from you and the clip part on the bottom.
If you do have an Integra SRS plug, you cut off the Civic SRS plug and color match the wires from the Civic harness.
Those with cruise control (LX/EX/Si)
To get the cruise control light to work, all you need to do is cut off the cruise control wire (red/blue) from the green plug and reconnect it with a wire that won't be used on the Integra cluster. For EKs, you can depin the Pink wire (washer fluid), cut the wire leaving the metal pin and some wire left, reconnect it with the cruise control wire, and repin into the cruise control slot on the Integra plug. Your cruise control light will now light up when engaged.
Those with a 92-95 Civic, cut off the cruise control wire from the green plug and take the Blue/White (low fuel light) wire with pin, then connect the cruise control wire to it. Once that is done, stick it in the cruise control slot of the Integra plug.
Those with ABS
For the 94-97 Integra clusters, the ABS wire is pinned into the 16-pin plug. Like with the cruise control modification (using an unused wire), cut off the Civic ABS wire, connect it, and pin it. For the 98-01 Integra clusters, the ABS is wired into the SRS plug. You will need to get the 98-01 Integrs SRS plug and connect the ABS wire from the Civic to the ABS wire from the plug.
Repinning a 96-00 Civic for an Integra cluster
The repinning process will only work on EK Civics because they use the same plugs as Integras. The EG wire pins are too large to fit into the EK Civic/Integra cluster plugs.
1. Get a medium sized safety pin. Large enough to be sturdy so it doesn't bend when trying to remove the wire and small enough to fit inside the pinhole.
2. On the left side of the plug, you will see a white clip. Use the safety pin and push it in to unclip it from the blue plug. If it breaks, it is ok; these clips break easy.
3. On the right side, there's another white clip. Do the same thing as you did in the second step.
4. In the middle of the blue plug, there's a small hook to attaches to the white piece. Take the safety pin and push that hook down. You should hear a 'click'.
5. Now, use your fingers and remove the top white piece. You will have to lift up the blue plug bridge on the top because the white piece has ridges that you have to clear. Once you attempt to remove it, you will know what I am talking about.
6. Now the bottom piece can slide out. You might need to use the safety pin to push that piece out. With this piece removed, you can now remove the wires from each pinhole.
7. Here are the two white pieces are removed. As you can see I broke one of the white clips. Again, the clips won't affect the wiring at all. I happened to removed these plugs from a Civic at a junkyard and it rains a lot here making the plastic brittle.
8. Look inside one of the pinholes. You will see more small hooks just like the one you seen in step 4. Take your little safety pin tool and insert it into the pinhole and try to push the hook down while pulling the wire gently. You have to wedge the pintip between the top of the plastic hook and the bottom of the metal wire pin. The wire will slide out when you have done it right. Remember a larger safety pin will make this step a little more difficult.
9. Here is a picture of one of the wires removed. Now that you know how to remove the wires, following the above diagrams and repin. The wires will slide back into the pinhole. Give the wire a little tug to make sure the wires are in there firmly. Good luck!
Putting an Integra cluster or 96-00 Civic cluster into a 92-95 Civic
Unlike the Integra cluster and 96-00 Civic cluster, the 92-95 Civic cluster plugs are completely different. You will not be able to repin the plugs. You will need to cut off the Integra/96-00 Civic cluster plugs leaving at least 5 inches of wire. If you have 96-00 Civic plugs and putting in an Integra cluster, you will need to repin the wires on the plug according to the Integra plug pinout. Vice versa if you have Integra plugs and swapping in a 96-00 Civic cluster. Now, you need to cut off the 92-95 Civic cluster plugs from your harness. Finally, you match the wires from the harness to the wires coming out of the Integra/96-00 Civic plug as in the diagram and connect them either by solder or butt connectors.
Results
Here are two pictures of my work in two EKs. Of course they won't have the best fitment, but close enough. I used pipe strapping to hold up the cluster, without it, there will be an even larger gap at the top. There will be a small gap at the top due to the cluster sitting further back from the gauge bezel.
Pipe Strapping
3/4" Pipe Strapping. I cut two pieces maybe 1.5-2" in length leaving the 2 small and 2 larges holes in tact. With the small hole to the edge, I trimmed a little of the two sharp corners so that the piece of strap can swivel to get a good mounting angle. Without the trimming, the piece will not be able to swivel. Using a small bolt and nut, the piece of strap is mounted to the cluster holes. Next, with the large hole at one end, I trimmed the outside corner when looking at the piece. Now, using screws, screw in the two pieces of pipe strapping to the screw locations.
Although not using pipe strapping, the following setup is similar to how I had it with the pipe strapping. The pipe strapping was a little wider than the brackets used below, so I had to trim the corners so they wouldn't rub with the cluster and mounting locations (you'll understand when you get there). Source: Merritt Johnson (www.merritr.com)
Great Source To Wire An S2000 Cluster Into 92-00 Civics and 94-01 Integras
http://www.dscustoms.com/s2000cluster.htm
1993-1995 Del Sol Cluster Wiring Diagram
https://honda-tech.com/zerothread?id=1053318&page=9
Modified by BlueIntegraBoy at 6:45 PM 1/15/2007
Old Nov 19, 2004 | 11:43 PM
95excoupe's Avatar
Default Re: 94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams (BlueIntegraBoy)
Thank you I keep on seeing these wiring diagrams and they all contridict each other. The reason why people always have that fuel gauge problem is cause the pre 98 clusters use pin C3 for the fuel gauge and the newer ones use C1 but everyone uses the same diagram.
Old Nov 20, 2004 | 04:13 AM
killer6993's Avatar
Default Re: 94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams (95excoupe)
Thank You.
Been waiting for the solid information. Too many maybe's or I think's in other posts.
Old Nov 20, 2004 | 04:17 AM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
Good job putting all years into one collective post, can't say I found a problem with the one I used for any of the two I have used with exception to the cluster that I didn't know which year it was from.
Old Nov 20, 2004 | 06:08 AM
eghatch4sale's Avatar
nice thanx!
Old Nov 20, 2004 | 07:04 AM
hndakd's Avatar
Default Re: (eghatch4sale)
good info i had a couple of problems with the ones i found when i put mine in
Old Nov 20, 2004 | 11:48 AM
Redline96LX's Avatar
* B A N N E D *
Thank you. And for some people that have tried and verified this??
Old Nov 20, 2004 | 04:18 PM
95excoupe's Avatar
Default Re: 94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams (Redline96LX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline96LX &raquo;</TD></TR><TR><TD CLASS="quote">Thank you. And for some people that have tried and verified this??</TD></TR></TABLE>
I just wired up my friends gsr cluster using this and everything is working fine so I can confirm the 94-97 into 96-00 civic diagram.
Old Nov 20, 2004 | 04:22 PM
ebp 99 si's Avatar
u should put this in the faq part
good info
Old Nov 21, 2004 | 06:27 AM
daidilus's Avatar
can i get one that is for an EG cluster into an EF?
Old Nov 21, 2004 | 10:32 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daidilus &raquo;</TD></TR><TR><TD CLASS="quote">can i get one that is for an EG cluster into an EF?</TD></TR></TABLE>
Use the above diagram along with this diagram. You need to change the VSS. https://honda-tech.com/zerothread?id=709958
Old Nov 21, 2004 | 10:55 AM
daidilus's Avatar
, i already have a DC2 cluster wired in, i got the wiring diagram and added the EG cluster plugs to my existing ones.....only things that worked was the turn signals though..i may have forgotten the power wire..i will try again when i get home!
Old Nov 21, 2004 | 11:38 AM
Bonez21's Avatar
Default Re: (daidilus)
98-01 ITR Cluster into a 92-95 Civic (cx)
Old Nov 21, 2004 | 01:26 PM
ek9hatch0WN3R's Avatar
Default Re: (Bonez21)
i was just about to flip out cuz im so sick of these posts, but thanks for having a search friendly thread about this that people can refer to.
good good ****!
Old Nov 21, 2004 | 03:51 PM
T-RO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bonez21 &raquo;</TD></TR><TR><TD CLASS="quote">98-01 ITR Cluster into a 92-95 Civic (cx)</TD></TR></TABLE>
Now thats pimp...
Old Nov 21, 2004 | 10:24 PM
Bonez21's Avatar
Default Re: (T-RO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T-RO &raquo;</TD></TR><TR><TD CLASS="quote">
Now thats pimp... </TD></TR></TABLE>
Thanx
Old Nov 21, 2004 | 10:29 PM
jdmsiR20's Avatar
i think all this thread needs is.... a sticky? that and pictures of the plugs possibly... so maybe folks wont ask which is a, b, or e?
good **** though
Old Nov 21, 2004 | 10:31 PM
Default Re: (jdmsiR20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmsiR20 &raquo;</TD></TR><TR><TD CLASS="quote">i think all this thread needs is.... a sticky? that and pictures of the plugs possibly... so maybe folks wont ask which is a, b, or e?
good **** though </TD></TR></TABLE>
Yeah, I dont have pics of the plugs. But the number of holes in each plug might be a clue.
Old Nov 22, 2004 | 09:42 AM
cxSHOE's Avatar
nice write up .. too bad i can use my itr cluster anymore (look in sig for reason)
amber to white sucks
Old Nov 29, 2004 | 10:36 AM
vtec69's Avatar
Default Re: 94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams (cxSHOE)
you tha man
Old Dec 2, 2004 | 09:56 PM
civic_hatchy's Avatar
finally somthing i've been looking for thanks alot
Old Dec 2, 2004 | 11:02 PM
ph8ed4life's Avatar
Default Re: 94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams (civic_hatchy)
Excellent post!! FAQ quality, I say. Written very nicely, just what I needed!!
Old Dec 29, 2004 | 07:09 PM
jdmek910's Avatar
Default Re: 94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams (ph8ed4life)
cant see the picks and i REALLY NEED TO!
Old Jan 23, 2005 | 01:58 AM
jdpfman's Avatar
i have a 95 gsr cluster and the harness
its going into a eg, can i just re pin every thing?
Old Jan 25, 2005 | 12:38 AM
94_HATCH's Avatar
Default Re: 94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams (jdpfman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdpfman &raquo;</TD></TR><TR><TD CLASS="quote">i have a 95 gsr cluster and the harness
its going into a eg, can i just re pin every thing?</TD></TR></TABLE>
First diagram
