B17 w/CTR pistons, what should I do next?
Old Nov 11, 2004 | 08:05 PM
blk_db2's Avatar
Default B17 w/CTR pistons, what should I do next?
First off here my setup:
Engine work : B17 with CTR +.25 pistons w/JE piston rings, balanced cleaned/polished crank, shot peen rods, new rod, main and thrust bearings, new water pump, oil pump and full gasket set….
Also: RS Akimoto SRI, 2.25” custom catback Borla exhaust, B&M FPR, VAFC II, Exedy organic….. the rest is still stock (header, cat, ecu, fuel system….etc.)
Currently at 149.8 whp & 108.4 wtorq. (not bad for a basically stock eng with pistons)
So my question is, what should I do next. Should I spend my next $1 – 1.5K on:
1. Header, high flow cat and RS*R exhaust
Or
2. Headwork (CTR or ITR cams and spring)
help I need some advice….
Old Nov 11, 2004 | 10:21 PM
TIroneous's Avatar
for goodness sake-let it BREATHE. Header, High flow cat, and exhaust...easily 160whp/
Old Nov 12, 2004 | 08:50 AM
blk_db2's Avatar
Default Re: (TIroneous)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TIroneous &raquo;</TD></TR><TR><TD CLASS="quote">for goodness sake-let it BREATHE. Header, High flow cat, and exhaust...easily 160whp/</TD></TR></TABLE>
after adding the header, cat and exhaust.... will I have to get it dyno tuned again..... I know if I was running stock pistons I wouldn't have to, but with this setup what do you think?....
Old Nov 12, 2004 | 04:10 PM
TIroneous's Avatar
Default Re: (blk_db2)
No, but i wouldn't frown on it.
dohcMONSTER
Apr 9, 2006 02:02 PM
Drian
Mar 27, 2004 09:09 PM
ITR.#1446
Nov 4, 2003 10:22 AM
2k1 GSR
Aug 3, 2003 04:16 PM
justBLZE
13
Jun 12, 2003 08:04 AM
