what are thoughs bolts that go into the side of the passenger side of the head called?Where the cool
b16a i have a coolant leak not to bad, but its definately noticeable, i'm pretty sure its though bolts that go into the head on the distributor side of the motor, i dont think the hoses are leaking, but i want to know how to fix it, should i take the bolts out cause their is like 3 of them that go into it with coolant, why would they be leaking, do i just clean them and put some teflon tape on them and screw em back in with new hoses even though i'm pretty sure their not whats leaking. Just wondering what their called how to fix the leak their? thanx
The coolant sensors? If they're leaking, drain the coolant from your block a little, take em out, put a LITTLE hondabond on the threads, and reinstall (torque properly!)
thanx i will try that, they will most likely be a pain to get loose though, being such a large size bolt. i will try that though thanx again.
JDM_SOHC
14
Aug 7, 2009 11:59 AM
