OBD0-OBD1 Conversion!!!
Old Nov 11, 2004 | 06:35 PM
Karterguy13's Avatar
Default OBD0-OBD1 Conversion!!!
If I made them would anyone want them? How much are you willing to pay without lowballing too much.
Old Nov 11, 2004 | 06:40 PM
drdisco69's Avatar
Default Re: OBD0-OBD1 Conversion!!! (Karterguy13)
to that.
I've seen them going anywhere from 140-200, so anywhere around that and you should be doing well.
Old Nov 11, 2004 | 06:43 PM
crxgator's Avatar
75 shipped...otherwise blown90hatch has em for i think 105 shipped with excellent customer service...
Old Nov 11, 2004 | 06:51 PM
sporkcrx's Avatar
How about you post a link about what pins go to what instead
(I need to make a harness)
Old Nov 11, 2004 | 10:03 PM
drdisco69's Avatar
Default Re: OBD0-OBD1 Conversion!!! (sporkcrx)
http://www.pgmfi.org/twiki/bin...-OBD1
Old Nov 12, 2004 | 01:08 AM
civickiller's Avatar
Default Re: OBD0-OBD1 Conversion!!! (drdisco69)
the one question i had was, when you convert to obd1. how do you check for codes ? doesnt obd 1 have like a plug where you just jump it with like a paper clip ? so does the conversion harness come with that ?
just wondering how you would check for codes
Old Nov 12, 2004 | 01:15 AM
sporkcrx's Avatar
Default Re: OBD0-OBD1 Conversion!!! (civickiller)
for 88-89's you jump the timing plug, and it shows it on the CEL. I forget for the 90-91. Just learned this today.
Old Nov 12, 2004 | 01:31 AM
92integra_gs's Avatar
do you offer warranty on that conversion?
Old Nov 12, 2004 | 02:43 AM
Default Re: (92integra_gs)
yeah i was searching after i posted and found the answer.
but after searching it brought up another question i had. on my stock d15 the sensor for the fans is on the back of the block with 2 wires. i noticed on my b18b, it didnt have that sensor. but i saw a sensor on the thermostat housing
so i was wondering is that, is the thermostat sensor used for the fans ? or do i just ahve to swap that sensor over from my d15 to the b18b so the fans will work ? or a better question, what do i ahve to do to get my fans to work
Old Nov 12, 2004 | 06:19 AM
Blown90hatcH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Karterguy13 &raquo;</TD></TR><TR><TD CLASS="quote">If I made them would anyone want them? How much are you willing to pay without lowballing too much.</TD></TR></TABLE>
Welcome to 1998 when using junkyard connectors to mass produce them was the norm.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator &raquo;</TD></TR><TR><TD CLASS="quote">75 shipped...otherwise blown90hatch has em for i think 105 shipped with excellent customer service... </TD></TR></TABLE>
Word. and that is with all brand new OEM connectors, pins, wires. With pins crimped by the same machine that does it for honda and a subharness for the extra sensors and a full instruction sheets.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civickiller &raquo;</TD></TR><TR><TD CLASS="quote">the one question i had was, when you convert to obd1. how do you check for codes ? doesnt obd 1 have like a plug where you just jump it with like a paper clip ? so does the conversion harness come with that ?
just wondering how you would check for codes</TD></TR></TABLE>
Ground the D4 pin on the OBD1 side and the check engine light will flash the code just like OBD1/2.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civickiller &raquo;</TD></TR><TR><TD CLASS="quote">yeah i was searching after i posted and found the answer.
so i was wondering is that, is the thermostat sensor used for the fans ? or do i just ahve to swap that sensor over from my d15 to the b18b so the fans will work ? or a better question, what do i ahve to do to get my fans to work</TD></TR></TABLE>
That is correct, on the OBD1 engines, the fan switch is on the thermo housing. I always suggest extending the wires and changing plugs to use the fan switch on the thermo housing.
Old Nov 12, 2004 | 01:41 PM
Default Re: OBD0-OBD1 Conversion!!! (Blown90hatcH)
Dam I guess Blown90hatch Schooled me. He answerd my thread b4 I could. He is right mine are junkyard made, but they work. Oh well If you guys do want one PM me and i can set something up, Otherwise it sounds like blown hatch makes a good one.
Old Nov 13, 2004 | 08:52 PM
bump
Old Nov 14, 2004 | 06:03 AM
Jaker's Avatar
If you're looking to make money off this post, I think it would be entirely innapropriate for you to pursue this thread. The correct way to go about this is to pay the owners of the site a fee, and advertise your wares in the Sponsor Marketplace.
Old Nov 14, 2004 | 07:35 AM
CRX_Control's Avatar
Default Re: OBD0-OBD1 Conversion!!! (Jaker)
Blown90hatch's harness are great, easy as 123 install
kptrulee
Jun 7, 2007 06:23 PM
blackboostcoupe
Jun 29, 2006 06:55 PM
All Day
Mar 8, 2006 06:11 AM
FaceTuned
May 2, 2005 09:04 AM
