Oil Catch Can install???
Old Nov 11, 2004 | 05:56 PM
StolenTeg's Avatar
Default Oil Catch Can install???
People say that when you install a catch can you disconnecet the hose that come out of the black thing (pvc?) into the intake manifold, black thing(pvc?) to catch can to intake manifold?
Is this the hose???
Old Nov 11, 2004 | 06:22 PM
non-VTEC's Avatar
Default Re: Oil Catch Can install??? (StolenTeg)
no that is a coolant hose from the throttle body to the IACV.
the hose you want it attatched directly to the PCV valve. you should be able to see it from the front of the intake manifold.
Old Nov 11, 2004 | 10:38 PM
jdm_cars's Avatar
Default Re: Oil Catch Can install??? (non-VTEC)
hehe.. yup i don't think you want to disconnect that hose...
hehe.. it is like the person above said a coolant hose from your throttle body to your IACV... your car will have weird idle and shoot coolant if that hose is disconnected...hehe...
BTW, I think you are looking for that PCV hose on the IM manifold, that should be the one you are looking for.
Old Nov 13, 2004 | 05:58 AM
StolenTeg's Avatar
Default Re: Oil Catch Can install??? (jdm_cars)
So is it this hose ???
Old Nov 13, 2004 | 06:27 AM
Dan GSR's Avatar
yes
Old Nov 13, 2004 | 09:40 PM
Chris F's Avatar
Default Re: Oil Catch Can install??? (Dan GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR &raquo;</TD></TR><TR><TD CLASS="quote">yes</TD></TR></TABLE>
Wait, no, that looks like a valve cover breather to me.
Look just below the valve cover breather--- there's a hose from the intake manifold to a plastic 90 degree fitting that should be your PCV valve, which attaches to a tube (below the intake manifold) to the crankcase.
Old Nov 13, 2004 | 09:58 PM
esponet's Avatar
thats the right hose, on 96 up LS motors, they did not have the pcv valve on the manifold that went to the block, instead the pcv is on the v/c
Old Nov 13, 2004 | 09:59 PM
Chris F's Avatar
Default Re: Oil Catch Can install??? (ccfries)
Best info I've seen on the topic.
http://www.beesandgoats.com/bo...l#PCV
Here's the stock PCV system.
Old Nov 13, 2004 | 11:51 PM
jdmotorsports's Avatar
on that b18b1 the red circled is the pcv hose. the barb upperleft of the oil cap is the breather hose. you can go off either of those, but you'll need vacuum off the intake manifold.
Old Nov 14, 2004 | 06:06 AM
StolenTeg's Avatar
Default Re: Oil Catch Can install??? (jdmotorsports)
[QUOTE=jdmotorsports]
What if i just put the catch can in the middle of the red line. Valve cover--&gt;Catch Can--&gt; Intake manifold?
Old Nov 14, 2004 | 06:28 AM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmotorsports &raquo;</TD></TR><TR><TD CLASS="quote">on that b18b1 the red circled is the pcv hose. the barb upperleft of the oil cap is the breather hose. you can go off either of those, but you'll need vacuum off the intake manifold.</TD></TR></TABLE>
I learn something new every day.
(steps quietly out of Integra forum...)
Old Nov 14, 2004 | 01:08 PM
StolenTeg's Avatar
luuisss
14
May 27, 2013 01:46 PM
MugenTGZ
May 22, 2013 01:57 AM
gnccracer18
Mar 24, 2008 06:14 PM
.one lane
Nov 13, 2005 11:41 AM
joebark
Sep 27, 2004 08:25 PM
