20-25 psi with aem fpr(stock rail mount)?
Old Nov 11, 2004 | 03:17 PM
redboost10's Avatar
Default 20-25 psi with aem fpr(stock rail mount)?
im in the process of doing my swap, b16a2 into a 97 hatch. im trying to see what i need to upgrade from running 14 psi to 20-25 psi. i know the simple things like, pretty much my whole fuel set up, injectors, fuel pump, ignition, fuel line. the only thing taht has me stumped is the fuel regulator, right now im running a aem fpr, the one that mounts on the stock location. will this work for the boost i plan to run? and also i know the feed line will have to be -8an ss feed line. is the stock fuel return hose going to be ok? thanks guys. i couldnt find any info on this.
if any info is needed about my setup just let me know.
Old Nov 11, 2004 | 04:39 PM
redboost10's Avatar
Default Re: 20-25 psi with aem fpr(stock rail mount)? (tgh99si)
does anyone know if itll be ok?
Old Nov 11, 2004 | 06:29 PM
redboost10's Avatar
please help
Old Nov 11, 2004 | 07:07 PM
m R g S r's Avatar
Stock FPR should be fine. Aeromotive are good if you want to upgrade.
Old Nov 11, 2004 | 07:28 PM
lev16gt's Avatar
Default Re: 20-25 psi with aem fpr(stock rail mount)? (m R g S r)
the aem fpr you already have will work fine. also, i'm pretty sure that you won't need to upgrade your lines unless you want to (if anything, just upgrade from the filter to the rail).....imo i would keep the stock lines and save some cash for other stuff.
Old Nov 11, 2004 | 07:45 PM
redboost10's Avatar
Default Re: 20-25 psi with aem fpr(stock rail mount)? (lev16gt)
awesome, so ill just upgrade from filter to rail with -8an, right? as for the lines, i was mainly concerned with the return hose. thank you for the help. ill stick with the aem fpr.
Old Nov 11, 2004 | 09:16 PM
redboost10's Avatar
from the fuel filter to the rail, is it -8 or -6 an ss line? for 20-25 psi, about 450-500 hp, which size? thank you
csubucky19
May 13, 2009 11:34 AM
sohctodohc
Apr 17, 2008 06:16 PM
oldbeefcake
Jan 12, 2004 07:44 AM
