99 TYPE SH SWITCHING MOTOR & TRANS TO OBDI SETUP
Old Nov 11, 2004 | 03:03 PM
Dragline's Avatar
Default 99 TYPE SH SWITCHING MOTOR & TRANS TO OBDI SETUP
Just wondering whats involved in doing this ,what do you do with they CKP & TDC that read of they crank
Old Nov 11, 2004 | 03:28 PM
Paul H22A4's Avatar
Default Re: 99 TYPE SH SWITCHING MOTOR & TRANS TO OBDI SETUP (dragline)
Way more trouble than its worth.
Old Nov 11, 2004 | 03:35 PM
satan_srv's Avatar
Are you swapping a 4th gen or JDM motor? The TDC has always read off the distributor, it's only the CKP that moved to the crnak for OBDII
Either:
-OBDI distributor
-cut at rewire OBDI dist plugs, pulling CKP wires back to dist (CKP is in the dist OBD1
-OBDII->Conversion Harness
- OBDI P13 ecu
or
- Swap OBDII distributor off SH to motor
- Swap OBDII oil pump and CKP sensor off SH to motor
- Swap Balancer Belt and Timing Belt gears off crank
- no change to wiring harnes
- OBDII P5M (aka non-SH) ecu
Old Nov 11, 2004 | 03:56 PM
Dragline's Avatar
Default Re: 99 TYPE SH SWITCHING MOTOR & TRANS TO OBDI SETUP (satan_srv)
I pulled the wires back to the dist for the ckp & tdc the tdc is read of the crank the only thing that reads of the dist is the cyp it's all wired but it won't let me rev past 3k
Old Nov 11, 2004 | 04:41 PM
Dragline's Avatar
anyone
Old Nov 12, 2004 | 12:05 PM
satan_srv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragline &raquo;</TD></TR><TR><TD CLASS="quote">I pulled the wires back to the dist for the ckp & tdc the tdc is read of the crank the only thing that reads of the dist is the cyp it's all wired but it won't let me rev past 3k </TD></TR></TABLE>
no it's doesn't...the TDC is at the dist on both models
are you using a conversion harness and an ecu? what ecu?
Old Nov 13, 2004 | 06:29 AM
Dragline's Avatar
So what 2 sensors read of the crank then, my service manual shows them reading of they crank and the wire colors match each sensor in the wiring diagrams, and I'am just running the stock 99 sh ecu no harness adapters
92EGSi
Aug 2, 2013 08:10 AM
1998typesh
Jul 6, 2011 05:51 PM
accordlxr
Oct 3, 2007 07:06 PM
ddenson
Jul 25, 2007 11:03 AM
fknslmd
Apr 20, 2004 03:09 PM
