stock shocks with coil overs...
Old Dec 25, 2001 | 04:56 PM
johnnyblaze's Avatar
Default stock shocks with coil overs...
i want to drop my honda civic w/ coil overs...if i could, how long can i use my stock shocks on skunk coil overs? is it bad to use stock shocks. or should i wait until i have enough for shocks and coils? and how long should i go without a camber kit?
Old Dec 25, 2001 | 05:01 PM
gsrvx's Avatar
New User
Default Re: stock shocks with coil overs... (johnnyblaze)
If I were you...I'd just save up for both the coilovers and shocks. That way...you can do it at once. You can use your stock shocks...but with stiffer springs...they will go out much quicker than they normally would.
Old Dec 25, 2001 | 05:20 PM
tEK_99's Avatar
Default Re: stock shocks with coil overs... (RK)
im riding on skunk2's...the ride is okay...not as bad as i thought it would be...but i agree with buying shocks with the coil sleeves...so you get that over with...as far as your wheels cambering...i would get it cambered asap...
_____________
Merry Christmas!!
spoonek4's Avatar
How low do u wanna go? If u wanna slam it down like 2.5"+ something like that u better get real coilovers to do it. To be honest some of the real coilovers can't really handle u lower it too much in a long term(say 2.5"+), coz some of them ain't short stroked.
Since I've seen blown stock shocks with coilover spring sets. I can pour those fluid out and all the dust cover broke like crazy and jamned inside the springs.
Well anyway, what year is your civic and how low do u wanna go?
Old Dec 25, 2001 | 07:43 PM
Default Re: stock shocks with coil overs... (spoonek4)
My civic is a 96 4-door with SI stocks.....I wanna drop it 1 1/2 - 2 inches...what do you think?
Old Dec 25, 2001 | 07:45 PM
Thanks for the info!
Old Dec 25, 2001 | 07:47 PM
misledyouth's Avatar
New User
personally if i was gona slam my car i woudl do it on shocks. cause i would not want to blow out a set of 1000 dollar + coilovers
jesse
Old Dec 25, 2001 | 11:20 PM
spoonek4's Avatar
1.5-2" should be OK for the stock shocks depends on the condition of your stock shocks right now and the road condition in your city. So, I can't guarantee.
For me I lowered my 99 civic DX with Kg/mm DR Racing springs right after I got the car from the dealer. It lower about 60mm front and 55mm rear. And before I swap it to a damper kit my stock shocks are still good. That's after like 1.5year.
U have to consider about getting another set of dampers to stand with the higher spring rates of the coilover springs anyway. KYB AGX is a pretty good choice. Cheap with pretty good performance. If u go for Koni or Bilstein, choose Bilstein since Koni is too rough. But Koni/Bilstein+springs is about the price of a set of real coilovers now.
Hard to make a decision eh? Just my 2cents if u have any more problem, let me know.
Old Dec 26, 2001 | 04:20 AM
Kalokohan's Avatar
New User
Definitely save up for shocks before you go to a shop to get them installed. That way, you get two birds killed with one stone. If you go any lower than 2", your stock shocks will probably last you 2 weeks.
Old Dec 26, 2001 | 04:55 AM
Hammett's Avatar
Mine lasts only 3 months. I had 3 inch drop!
Old Dec 26, 2001 | 09:31 AM
hondachick81's Avatar
i want to drop my honda civic w/ coil overs... and how long should i go without a camber kit?
a friend of mine has his civic dropped and he doesn't have a camber kit. You don't necessarily have to get one....but all depending on how much you drop it. my friend doesn't have coil-overs(he has lowering springs) but without a camber kit his tires wear alot faster and just on the one side. he doesn't want to wear his nice set, so he rides around with the stock wheels
Old Dec 26, 2001 | 10:11 AM
HENRY's Avatar
New User
If you're going to go with anything LESS then a 2" drop then i would stick with stock shocks as long as they're in good shape. I rode around on stock shocks with Neuspeed race (2.25" drop) for over 2 years and when i swapped out the stock shocks for Tokico's, they were in perfect shape. I would say the same about a camber kit too. If you're only going to lower it about 1.5", just get a 4-wheel alignment afterwards. Good luck
aaronfunstuff
Mar 6, 2014 03:26 PM
jessedm
Jul 1, 2010 07:37 AM
stevn
Oct 16, 2005 08:14 PM
pburke23
May 26, 2004 09:08 PM
thaigsrdrv16
Jul 4, 2002 04:37 PM
