Little bottom end advice....
Old Nov 11, 2004 | 02:10 PM
h22a193's Avatar
Default Little bottom end advice....
Im going to hone block to fit OS type s pistons.
Question, Do they come with wrist pins?
should I get lighter forged rods? Is it worth it?
Should I get new bearings mains, and rods?
Or can I just used mine and just get arp rod bolts? They have 95 k on them.
Old Nov 11, 2004 | 02:15 PM
2kflamedlude's Avatar
Default Re: Little bottom end advice.... (h22a193)
You will be fine with that.. I dont know about wrist pins..
Old Nov 11, 2004 | 02:30 PM
WillsH22Accord's Avatar
most of type s piston sets that ive seen come with rings and pins.
Old Nov 11, 2004 | 02:51 PM
h22a193's Avatar
Default Re: (WillsH22Accord)
will i be alright using the stock bearings?
Old Nov 11, 2004 | 04:28 PM
LudeyKrus's Avatar
The pistons should come with new rings and wrist pins.
No, forged rods aren't really needed in your application.
Yes, if you are in there replacing the pistons, you should go ahead and replace the main and connecting rod bearings.
ARP rod bolts are not needed on your application.
Old Nov 12, 2004 | 10:24 AM
h22a193's Avatar
Default Re: (LudeyKrus)
its going to be a built na motor, hopefully shooting for some good numbers, with honda bottom end, so do need new oem rod bolts, or can I reuse the old ones?
Old Nov 12, 2004 | 04:26 PM
adamh23's Avatar
Default Re: (h22a193)
IMO stay genuine honda in the bottom end. You can reuse all your fasteners I even reuse the head bolts.
Beware of honing that block, our blocks have teflon like coating on the cylinder wall. Service manual says 600 grit or higher, and suggests not to hone. Some minor wear in a vertical fashion is normal and nothing to be alarmed about.
Helm has some very useful info
http://www.helminc.com/helm/pr...2AVX5
Good luck
Adam
Old Nov 13, 2004 | 10:31 AM
PrettyLude's Avatar
its called a nikasil coating on the liners
Old Nov 13, 2004 | 12:05 PM
LudeyKrus's Avatar
Default Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">its called a nikasil coating on the liners</TD></TR></TABLE>
It's not nikasil, it's FRM.
Old Nov 13, 2004 | 08:59 PM
tomtom211's Avatar
soo you can't hone H22 blocks?
How do you squeeze in the OS pistons?
Old Nov 14, 2004 | 06:53 AM
ludegetsmwet's Avatar
Default Re: (tomtom211)
Honing the block is scratching the inner surface to allow the piston and rings to flow smoother without creating suction and eventually causing serious problems, and boring is widening the diameter of the cylinder. if you need to bore it out more than go ahead but honing does not allow for more room
Old Nov 14, 2004 | 06:54 AM
h22a193's Avatar
well thanks for all the help, I think I am just going to be getting a h22a and pulling my motor, and building it slowly, probably will sleeve it eventialy, but it just takes time! I have a helms, and its the best thing you can buy when it comes to working on the car.
Old Nov 14, 2004 | 10:16 AM
LudeyKrus's Avatar
Default Re: (ludegetsmwet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludegetsmwet &raquo;</TD></TR><TR><TD CLASS="quote">Honing the block is scratching the inner surface to allow the piston and rings to flow smoother without creating suction and eventually causing serious problems, and boring is widening the diameter of the cylinder. if you need to bore it out more than go ahead but honing does not allow for more room</TD></TR></TABLE>
Not necessarily. Honing is more for allowing the rings to seat properly in the cylinders.
Boring is when you need to make a bigger change in diameter of the cylinder, and it also will make sure your cylinder walls are perfectly round and straight.
Honing will take some material off, but not too much. It will take off enough to fit in the OS pistons, but that's about it.
TravisBiggie
Apr 10, 2013 08:21 AM
prodragEG
Sep 29, 2007 11:10 PM
egvtec
Dec 12, 2005 03:49 PM
Dirtfall
Sep 16, 2005 08:21 AM
CRX Lee
Feb 9, 2004 08:39 AM
