Car run's but idles really rough and doesn't want to accel.
Start of this way, the car is a 99 accord 4cyl. percision SC52, percision 780cc inj, AEM fuel rail, Aeromotive FPR, and crane ign. system. w/coil all running with e-manage. I have 10w10ohm res. wired to the inj. and I think this may be the problem. The car will idle but its very poor. If its given just a little gas the car will die. But if its floored it will hessitate and jump up in rpm's. I checked the plugs and there a light brown color and if I give it gas the turn jet black and get wet. So I'm thinking that the inj. are just dumping fuel. Before on the 440cc injectors(RC high imp.) the car ran fine but I had them maxed out and wantted alot more room to grow. My question is this would the running problem more then likely be due to the resistors or the e-manage being maxed out. I was going to try a resistor pack if I could fine one. If this didn't fix it the car will have to sit till I get enough money for the AEM EMS. To help out the e-manage can control inj's up to 150% larger then stock and the stock size I believe is 230cc. Please help I want to try and get it running even if it has to sit till I get the EMS. I just don't want to buy it if there is no need for it.
I figured that much out. I was wanting to know if somebody knew if it could be the resistors vs honda resistor pack or if the e-manage is not controling them because there to big. If the e-manage is not controling them then I will get the AEM EMS and let the car sit till I can affort it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbowa »</TD></TR><TR><TD CLASS="quote">I figured that much out. I was wanting to know if somebody knew if it could be the resistors vs honda resistor pack or if the e-manage is not controling them because there to big. If the e-manage is not controling them then I will get the AEM EMS and let the car sit till I can affort it.</TD></TR></TABLE>
resistor's work fine. however i think some accords COME with a resisotr box.
and i dont think emanage can control anything thats 2X bigger than stock.
So then my answer would be that my inj. are to big for the emanage? It looks like the cars sitting till I can get an EMS
CimorelliCRX
Apr 7, 2022 12:16 PM
akura18
Jan 24, 2007 02:13 PM
